Results 1 to 6 of 7
01-15-2007 12:25 PM #1
A big one...second HD output options for 622
We're about a day or so away from finally getting another HDTV for the bedroom.
We thought of getting a second 622 but don't really want to because we want all our content on a single box.
I've looked at a few solutions but they depend on the 622 itself.
1. Can the 622 output over HDMI and component at the same time?
2. Can you "split" a component connection?
I much prefer component over HDMI on my 622 and Samsung 61" 1080p DLP but the bedroom is getting a bottom dollar Maxent or Vizio 42" 720p. Can I leave the component on the big TV and run HDMI to the bedroom, approx 23' by the time it goes down in the basement and back up.
How about splitting the component signal? I'd split it off before it went into my Yamaha AVR and run it into the bedroom.
What would be nice is if the 622 could encode ATSC and pump it out over coax.
I would take a 622 if they would link themselves up via ethernet and share content.
Anyone doing this or know of a good solution?
01-15-2007 01:23 PM #2
It is possible to split the component signal. I'm doing it. The cheapest way I found is this:
http://www.inday.com/hdda2/hdda2.htm
Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
The video component splitter works great.
Then you can either run an analog audio signal out of the composite jacks or use a toslink splitter. Monoprice is a good source for a cheap toslink splitter. I found splitting the audio with the cheap splitter to be a little frustrating. The splitter will either work great or not at all. I think the first one I tried was a defective. So you might want to buy a few of them just in case the first one is defective. Or if you can live with an analog sound source you might save frustration just going analogue on the sound.
01-15-2007 01:39 PM #3
01-15-2007 02:58 PM #4
Running HDMI and Component should work fine, until the (almost) inevitable HDMI problem rears it's ugly head and leaves you with just component.
Correct me if I'm wrong, but I don't think that has been completely corrected yet?
01-15-2007 07:43 PM #5
01-15-2007 10:29 PM #6"You are correct sir! "
ADVERTISING BOX
Sometimes it sucks to be right.
Incidentally, my HDMI port quick about 3 months ago. I switched to component. Haven't checked the threads here on that subject in a while and was hoping the situation had improved.
Register To Reply
