Quantcast
DISH 500 mast vs. DISH 1000+ mast
Those listed below are our PROUD SatelliteGuys GOLD Sponsors!
Applied Instruments glorystar.tv satelliteavgs tele-satellite.com
Page 1 of 2 12 LastLast
Results 1 to 6 of 10
  1. #1
    Join Date
    Feb 22nd, 2007
    Posts
    9
    Post Thanks / Like
    Can I replace my DISH 500 with the DISH 1000+ without changing the mast? I have the mast foot hardware for the 500 bolted into the attic with the nuts in a very tight space. I would hope the mast and footprint are the same on the 1000+. Sure don't want to drill any extra holes either.
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Jun 8th, 2006
    Location
    Denver, CO
    Posts
    1,246
    Post Thanks / Like
    I'm sure someone will correct me if I'm out in (D*s) left field.
    The Dish 1000 is a little larger than the Dish 500.
    The Dish 1000+/500+ is almost the size of the SuperDish 121/105, thefore....
    Although the + dishes use a 1 5/8" mast, the mast is longer so that the larger dish pan has room to be adjusted; and also has struts to help keep it stable with its higher wind surface.
    So the answer is - maybe.
    If there is not enough room, maybe you can leave the foot, and just replace the mast. Then you should also consider mounting the 2 struts.
    Here's the best link I can find right now, other than the tech specs from Dish.
    http://www.dishstore.net/product_inf...roducts_id=286
    Get rid of this ad below, as well as the link redirect by becoming a Supporting Pub Member
  4. #3
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! whitewolf8214 did! Help Support The Site And Get Rid of the Syndicated Ads, whitewolf8214 did! If you enjoy the site consider supporting it, whitewolf8214 did! Be COOL like whitewolf8214 and Click a Star and become a Supporting Pub Member today!
    Join Date
    May 13th, 2004
    Location
    Space
    Posts
    12,550
    Post Thanks / Like
    I had the 500 and went to the 1000 plus and is alot bigger and had to change the whole thing out and put it on the roof instead of the side of the house.You wouldn't believe how much bigger it is.I believe you will have to change it out but some tech probably might agree or disagree.
  5. #4
    Join Date
    Jun 8th, 2006
    Location
    Denver, CO
    Posts
    1,246
    Post Thanks / Like
    I would, I have 2 SuperDishes between 2 accounts, and not counting the wing dishes.
  6. #5
    Join Date
    Jun 3rd, 2006
    Location
    West Texas (midland)
    Posts
    1,921
    Post Thanks / Like
    Get Rid of this Ad! Register Today!
    The 500+ mast is reinforced, a 500 mast will probably eventually lead to failure, especially if it will not be wind protected.
    It can work, but your better off replacing.
    Struts are neccessary, it's a heavy dish/lnbf assembley.
    If it goes on the roof at last ditch option, make sure the center of the mast and struts are in a raftor.
    Personally you wouldn't see one on my roof/fascia. It would be into a brick wall if I had the option, low to the ground.
  7. #6
    Join Date
    Feb 22nd, 2007
    Posts
    9
    Post Thanks / Like
    Thread Starter
    ADVERTISING BOX
    Is the 500 mast foot the same as the 1000+ mast foot? If so, I will leave the foot and replace everything up including the support struts.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
