Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: FTA package?
  1. #1
    Join Date
    Jun 24th, 2007
    Posts
    49
    Post Thanks / Like
    FTA package?
    I was thinking of getting the glorystar FTA package. I had skyangel with my dish top 250, mostly because Sky angel was there, and for the family content, not the religious. Now that sky angel is defunct, I was looking at glorystar to replace it, but I'd be just as if not more interested in the other FTA programming. So I'm thinking I should get some more generic FTA package with a motor rather than the glory star one with the two fixed lnbs.
    Athough I have put up a couple of simple DBS dishes (dish 500s, etc) I am not by any means a person of knowledge when it comes to this sort of thing. So if there's a simple FTA package with everything you need and some directions (like the glorystar package says they have) I'd be interested.
    Is there a FTA package that has the dish, receiver and instructions simple enough for a non techie to install? Another thing, my lot has many trees on the edge, and I have three dishes, one each for 109, 110 and 61.5 which is out in the yard about 80 ft away. That's probably where I'd put this new dish. I'm just wondering if the glorystar system, since it only looks at two sats would be more of a sure thing, for line of sight and less tech knowledge needed to install.
    TIA
    pat
  2. # ADS
    Register Today & This Ad Goes Away! Syndicated Advertisement
    Join Date
    Always
    Posts
    Many
    Reigster at SatelliteGuys
  3. #2
    Join Date
    May 6th, 2005
    Location
    Metro New Orleans, LA
    Posts
    6,566
    Post Thanks / Like
    Our sponsor merchants have a selection of dish/LNB/motor packages, and offer excellent technical support (as well as support here on this forum). Installing a FTA dish is more complicated than a DBS dish; the aim is more critical, and you must use VERY slow movements when you adjust the dish to correctly find the signal. Once you get the hang of it, however, you'll be able to aim a Ku dish in a matter of a couple of minutes. Aiming a dish with more than one LNBF requires more skill, since you'll have to peak both LNBFs without losing signal on one or the other.
    Current systems: 3X GEOSATpro microHD PVRs; Digitrans DTE-7150 DVB/Digicipher II; SiliconDust HDHomeRun ATSC/QAM networked tuners; fixed 1 meter Channel Master dish with Eagle Aspen P870 FSS stacked Ku LNB; 2X 3ABN 36" dishes with Sadoun KBSL1 stacked Ku LNBFs on Powermax SG-9120B H-H motors; fixed Sadoun SD180G 1.8 meter dish with Eagle Aspen B1SAT stacked C LNBF; Winegard Square Shooter OTA DTV antenna
  4. #3
    Join Date
    Aug 27th, 2004
    Posts
    928
    Post Thanks / Like
    The Glorystar package is by a sponsor here, Satellite A/V. I've got the Glorystar package and it's pretty easy to setup if you've done a DirecTV dish. Same concept. One thing though is that I can easily pick up a motor later and just go with a single LNB if I want to convert it to a fully motorized FTA system. As it is, you can fully scan for FTA channels on the 2 sats it points to so you don't have to have just the religious channels. Lots of international channels on GA25 and AMC4 if you're into that stuff.
  5. #4
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! SatelliteAV did! Help Support The Site And Get Rid of the Syndicated Ads, SatelliteAV did! If you enjoy the site consider supporting it, SatelliteAV did! Be COOL like SatelliteAV and Click a Star and become a Supporting Pub Member today!
    Join Date
    Sep 3rd, 2004
    Location
    Roseville, CA
    Posts
    6,085
    Post Thanks / Like
    If you are interested in a motorized version of the equipment offered for the Glorystar system, check out this system.
    Mercury II Motorized 90cm System
    It is the same high quality equipment with the addition of a GEOSATpro GS120 motor.
    The installation guide for the motorized Mercury is
    HERE
  6. #5
    Join Date
    Jun 24th, 2007
    Posts
    49
    Post Thanks / Like
    Thread Starter
    Quote Originally Posted by Tron View Post
    Okay, dumb question. If you are using a motor to get to see more than one sat, do you have to aim at each one, or do you aim at one sat and the rest fall in line?
    After cruising the offerings, I'm thinking of waiting for the coolsat 8100 since i have and HDTV, and I'm used to a PVR. Should I get the dish, etc, first, to make sure I can even see the sats? and is there a way I can be sure of LOS before investing in an expensive receiver?
  7. #6
    Help Keep SatelliteGuys For All, Click a Star and Become a Supporter! brentb636 did! Help Support The Site And Get Rid of the Syndicated Ads, brentb636 did! If you enjoy the site consider supporting it, brentb636 did! Be COOL like brentb636 and Click a Star and become a Supporting Pub Member today!
    Join Date
    Jun 24th, 2006
    Location
    5 miles N of Saugatuck, Mi
    Posts
    4,270
    Post Thanks / Like
    When you correctly do the original motor setup ( on your true south satellite ) , and verify it ( or fine tune it on anther bird further away ) , then they all fall into line and USALS should nail them all.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
