DishNetwork Uplink Activity Report - 4/2/2008 3:10pm - 631 changes
OK someone help me here, in the "channel additions" this happened:
6495(40) - WJSU [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Available)(Anniston, AL)
6496(42) - WIAT [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Available)(Birmingham, AL)
6497(13) - WVTM [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Available)(Birmingham, AL)
6498(6) - WBRC [MPEG4 HD] added to EchoStar7 119W TP 09 Deep South beam (Available)(Birmingham, AL)
Then in the "channel moves" this happened:
6495 - WJSU moved from EchoStar7 119W TP 09 Deep South beam to Echostar12 61.5 TP 09 Area 9 beam (A)(Anniston, AL)
6496 - WIAT moved from EchoStar7 119W TP 09 Deep South beam to Echostar12 61.5 TP 09 Area 9 beam (A)(Birmingham, AL)
6497 - WVTM moved from EchoStar7 119W TP 09 Deep South beam to Echostar12 61.5 TP 09 Area 9 beam (A)(Birmingham, AL)
6498 - WBRC moved from EchoStar7 119W TP 09 Deep South beam to Echostar12 61.5 TP 09 Area 9 beam (A)(Birmingham, AL)
i think they were already in "EchoStar7 119W TP 09 Deep South beam", but does this mean they are no longer on 119 and are now on 61.5?
They just found away to make $60 bucks off you, or force you to extend your contract 2 years, by making you get a 2nd dish, welcome to the club.
140 - ESPN moved from EchoStar7 119W TP 04 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam and changed to MPEG4 SD (A)
142 - ESNWS moved from EchoStar7 119W TP 04 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam and changed to MPEG4 SD (A)
143 - ESPCL moved from EchoStar7 119W TP 04 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam and changed to MPEG4 SD (A)
144 - ESPN2 moved from EchoStar7 119W TP 04 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam and changed to MPEG4 SD (A)
148 - ESPNU moved from EchoStar7 119W TP 04 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam and changed to MPEG4 SD (A)
200 - CNN moved from EchoStar7 119W TP 19 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam and changed to MPEG4 SD (A)
214 - TWC moved from EchoStar7 119W TP 06 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam and changed to MPEG4 SD (A)
Anyone with a dish at 61.5 getting these channels from 61.5? What happens if you have 119 also which channel will the receiver choose, MPEG2 or MPEG4. That's of course if you have a ViP receiver.
Part of the problem is that 61.5 spot beams are not using unique channel numbers so this is probably confusing the automated program. There are several sets of locals in the 5150-5153 channel range. Same goes for other ranges in the 5000 channel area.
See ya
Tony
Could we interpret the moving of locals to 61.5 to mean that more room is being made for national HD on the other sats?
D
DishNetwork Uplink Activity Report - 2/23/2008 5:30am - 27 changes
D
DishNetwork Uplink Activity Report - 4/9/2008 1:11pm - 1 change
Similar threads
D
Replies
Views
3K
DigiDish Uplink Report
D
D
Replies
Views
3K
D
