3/4/2009 2:28pm - Uplink Activity Report - 66 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/4/2009 2:28pm - 66 changes
Uplink Comparison Range: 03/04/2009 01:57P - 03/04/2009 02:28P
Channel Additions:
775 - AGAPY [MPEG2 SD] added to Anik F3 118.7W TP 19 ConUS beam (NA)
4205(205) - FXNWS [MPEG4 HD] added to Ciel-2 129W TP 28 ConUS beam (A) (H)
4205(205) - FXNWS [MPEG4 HD] added to EchoStar3 61.5W TP 27 ConUS beam (A) (H)
4206(206) - FOXB [MPEG4 HD] added to Ciel-2 129W TP 28 ConUS beam (A) (H)
4206(206) - FOXB [MPEG4 HD] added to EchoStar3 61.5W TP 27 ConUS beam (A) (H)
4287(387) - CI [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (A) (H)
4287(387) - CI [MPEG4 HD] added to Echostar12 61.5W TP 21 ConUS beam (A) (H)
5151(47) - WTEV [MPEG4 HD] added to EchoStar8 77W TP 05 ConUS beam (NA)(Jacksonville, FL-CBS)
5153(30) - WAWS [MPEG4 HD] added to EchoStar8 77W TP 05 ConUS beam (NA)(Jacksonville, FL-FOX)
5171(21) - WHP [MPEG4 HD] added to EchoStar8 77W TP 01 ConUS beam (NA)(Harrisburg, PA-CBS)
5180(49) - KTKA [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 8 beam (NA)(Topeka, KS-ABC)
5182(27) - KSNT [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 8 beam (NA)(Topeka, KS-NBC)
5183(43) - KTMJ [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 8 beam (NA)(Topeka, KS-N/A)
5193(16) - KLRT [MPEG4 HD] added to EchoStar8 77W TP 09 ConUS beam (NA)(Little Rock, AR-FOX)
5260(19) - WHOI [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Peoria, IL-ABC)
5261(31) - WMBD [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Peoria, IL-CBS)
5262(25) - WEEK [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Peoria, IL-NBC)
5263(43) - WYZZ [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Bloomington, IL-FOX)
8119(43) - WSAH [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 04 (NA)(Bridgeport, CT-IND)
8119(43) - WSAH [MPEG4 SD] added to Echostar12 61.5W TP 15 Area 6 beam (NA)(Bridgeport, CT-IND)
8166(40) - WMGM [MPEG2 SD] added to EchoStar10 110W TP 26 Spotbeam 04 (NA)(Wildwood, NJ-NBC)
8166(40) - WMGM [MPEG4 SD] added to Echostar12 61.5W TP 11 Area 5 beam (NA)(Wildwood, NJ-NBC)
Channel Removals:
595 - TVCI (A) removed from EchoStar3 61.5W TP 18 ConUS beam
616 - PTV (A) removed from EchoStar3 61.5W TP 18 ConUS beam
622 - APUNJ (A) removed from EchoStar3 61.5W TP 18 ConUS beam
902 - GEONW (A) removed from EchoStar3 61.5W TP 18 ConUS beam
6101 - PTV (A) (H) removed from EchoStar3 61.5W TP 08 ConUS beam
6104 - APUNJ (A) (H) removed from EchoStar3 61.5W TP 10 ConUS beam
6110 - GEONW (A) (H) removed from EchoStar3 61.5W TP 12 ConUS beam
6112 - TVCI (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
7165 - WPTY (NA) removed from Echostar12 61.5W TP 05 Area 9 beam(Memphis, TN-ABC)
7281 - WISC (NA) removed from Echostar12 61.5W TP 05 Area 4 beam(Madison, WI-CBS)
8351 - WKRC (NA) removed from EchoStar8 77W TP 04 ConUS beam(Cincinnati, OH-CBS)
8988 - KWKT (NA) removed from Echostar12 61.5W TP 11 Area 3 beam(Waco, TX-FOX)
Channel Moves:
4800 - TMP30 [MPEG4 HD] moved from EchoStar11 110W TP 07 ConUS beam to Ciel-2 129W TP 18 ConUS beam (NA)
4801 - TMP31 [MPEG4 HD] moved from EchoStar11 110W TP 13 ConUS beam to Ciel-2 129W TP 18 ConUS beam (NA)
4802 - TMP32 [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
7025 - KXVA [MPEG2 SD] moved from EchoStar1 148W TP 31 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(Abilene, TX-FOX)
7063 - KIDY [MPEG2 SD] moved from EchoStar1 148W TP 15 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(San Angelo, TX-FOX)
Channel Package Flag Changes:
205 - FXNWS [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed package flags (A)
205 - FXNWS [MPEG4 SD] - Echostar6 72.7W TP 03 ConUS beam changed package flags (A)
574 - NDTV [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
574 - NDTV [MPEG2 SD] - EchoStar3 61.5W TP 08 ConUS beam changed package flags (A)
585 - AAJTK [MPEG2 SD] - EchoStar1 148W TP 25 ConUS beam changed package flags (A)
585 - AAJTK [MPEG2 SD] - EchoStar3 61.5W TP 12 ConUS beam changed package flags (A)
794 - AAJTK [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
5250(13) - KRDO [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Colorado Springs, CO-ABC)
5251(11) - KKTV [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Colorado Springs, CO-CBS)
5252(5) - KOAA [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Pueblo, CO-NBC)
5253(21) - KXRM [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Colorado Springs, CO-FOX)
5250(13) - KTNV [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Las Vegas, NV-ABC)
5251(8) - KLAS [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Las Vegas, NV-N/A)
5252(3) - KVBC [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Las Vegas, NV-NBC)
5253(5) - KVVU [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Henderson, NV-FOX)
5260(8) - KOLO [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-ABC)
5261(2) - KTVN [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-CBS)
5262(4) - KRNV [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-NBC)
5263(11) - KRXI [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-FOX)
5250(6) - KIVI [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H)(Nampa, ID-N/A)
5252(7) - KTVB [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H)(Boise, ID-NBC)
5253(12) - KTRV [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H)(Nampa, ID-FOX)
5261(4) - KGBT [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 52 changed to Available (H)(Harlingen, TX-CBS)
5262(23) - KVEO [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 52 changed to Available (H)(Brownsville, TX-NBC)
7524(26) - KTEND [MPEG2 SD] - EchoStar10 110W TP 20 Spotbeam 21 changed to Available (H)(Ada, OK-NBC)
7524(26) - KTEND [MPEG4 SD] - Echostar12 61.5W TP 01 Area 3 beam changed to Available (H)(Ada, OK-NBC)
19214 - HISAP [DATA] - EchoStar7 119W TP 02 ConUS beam changed package flags (A)
Channels in the system: 6508
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
For those concerned about FOX News package change:
CHNG 205 FXNWS MPEG2 SD Tp 6 EchoStar 7 119w AT200? PREV
TO 205 FXNWS MPEG2 SD Tp 6 EchoStar 7 119w AT100?
CHNG 205 FXNWS MPEG4 SD Tp 3 EchoStar 6 72.7w AT200? PREV
TO 205 FXNWS MPEG4 SD Tp 3 EchoStar 6 72.7w AT100?
Since FOX News HD was turned on individually to each receiver there is no activity here except for it being added to the Phantom package.
What HD package is on the 42xx range? Hawaii, Alaska, PR who?
IMO, it's pretty obvious that their priority is to launch HD locals right now. If and only if there's bandwith available after they're done, then they'll turn on some HD Nationals.
You mean the Japs.
That is not correct.
There is plenty of bandwidth available for all the National HD channels that people are asking for.
Once Ciel-2 came online, any bandwidth restraints ended.
The only possible reason for not turning on National HD is marketing.
D
3/5/2009 1:57pm - Uplink Activity Report - 2 changes
D
3/12/2009 2:59pm - Uplink Activity Report - 1 change
Similar threads
D
Replies
Views
3K
DigiDish Uplink Report
D
D
Replies
Views
3K
D
