Vizio codes for dish remote
  • WELCOME TO THE NEW SERVER!
Has anyone figured out how to get the tv/input button to work on the dish remote with a Vizio tv?
That info is listed in the Vizio Users Manual.
Using a Cable or Satellite Remote
Your VIZIO remote uses codes 000, 047, 050, 067, 329, 331 and 339 to work your LCD HDTV. To use a
cable or satellite remote to work the LCD HDTV, refer to your cable or satellite remote user guide for
more information on how to program the remote. If your cable or satellite remote uses a 5-digit code (like
most Direct TV units), first try 11758 and then, if that does not work, 10178. If your cable or satellite
remote uses a 4-digit code, try 1758 and then 0178 as an alternative. If your cable or satellite remote
uses a 3-digit code (Echostar or Dish Network for example), use code 627.
Note: Some buttons may not function as expected on your cable or satellite remote. Typically power,
volume and mute will work.
But does the TV/Video button on the Dish remote change the Vizio inputs? That is what I think everyone is looking for. Including myself. ;)
I got mine to work using a 20.0 IR dish remote. You have to read the learning remote procedure and program in that particular button on the Vizio remote. There is a thread on here somewhere that goes through the steps.
