Turn off no script.(Your a pub member you dont need it now anyways)
vB said:KimmiKat, you do not have permission to access this page. This could be due to one of several reasons:
1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Your browser window is too small for the 'as-designed' page size. Make your browser window larger to "fix" it. If I shrink my browser, it also gets the overlap.I didn't see this reported yet, but notice, on the right, the search window covers up whatever link hides behind it.
i only have this issue on my mobile browserI have the same problem using FF (v3.6.12), not using no script. I've had the problem since the switchover too, just not enough of an irritant to bring up previously. But since you asked, ....
Just checked IE6.0, same problem with overwrites in the menu bar.
same here and no issues as wellI am on 3.6.11 here with no issues.
Its a bug in the software, its a conflict between vBulletin and vbSEO software causing the issue.
Lots of sites waiting for a fix on that one.![]()
This is still broken when I checked it tonight.I noticed that when I select the "My Posts" under the "Quick Links" in the second-level menu bar at the top, I get the list of threads that I started, not my posts. If I click on my name next to my avatar and select "View Forum posts", I get the list of my last posts. Selecting "My Threads" in the Quick Links brings up the same list as "My Posts".
This is what I see, in both IE6 and FF6.12:
Maybe move "Chat Room" down too ? How often is it used ? If not too often, does it need to take that real estate ?I am going to see if I can move the new posts down from the top bar onto the second row. That should take care of the overlap issue for the members who are viewing the site as a lower resolution.
