How to stop Dish Network DVR from turning itself off?
  • WELCOME TO THE NEW SERVER!
booyadan16
7
Chico, CA
I have a Dish Network VIP722k HD receiver that I have running 2 tv's in my house. It is connected to my primary tv via hdmi cable. My problem is that I also have an xbox connected to that tv and whenever I change the input from "HDMI1" to "Component1" to use the xbox the Dish Receiver goes into standby and the person watching tv in the other room cant watch anymore. Does anyone know if there's a way to change some settings and make the receiver stay on even though its input is not selected on the primary tv? Thanks
I do not have this problem with a 722 nor with a 612, both of which are connected via HDMI. The receivers basically never shut off completely (or even go into standby) when I switch inputs on the TVs.
I have a Dish Network VIP722k HD receiver that I have running 2 tv's in my house. It is connected to my primary tv via hdmi cable. My problem is that I also have an xbox connected to that tv and whenever I change the input from "HDMI1" to "Component1" to use the xbox the Dish Receiver shuts itself off and the person watching tv in the other room cant watch anymore. Does anyone know if there's a way to change some settings and make the receiver stay on even though its input is not selected on the primary tv? Thanks
I have the same setup as well.I have my 722 on my HDMI 1 INPUT and my XBOX on HDMI 2 INPUT.Sounds like you may need to go into the menu settings on your tv and /or your 722.It shouldnt be doing that.How many hdmi outputs do you have on your tv?
*EDIT
Sorry, it goes into standby, it doesn't turn itself off, poor wording on my part.
I looked through my receiver settings but didnt really see anything that caught my eye. I saw that you can change the time period it takes for the receiver to go into standby but it was already set at 4 hours which is fine.
What brand of TV do you have?
I'm wondering if the TV has some sort of "HDMI control" (different brands call it different names, ie Samsung calls it Anynet).
Every time I've seen a problem with HDMI control, normally it's the receiver controlling the TV (such as turning it on when it does the nightly updates).
booyadan16 said:
*EDIT
On the 612 you do this....
1 MAIN MENU
2 PREFERENCES
3 INACTIVITY STAND BY
4 There are 2 windows. The one on the left in to choose enable or disable the Standby Activation.
Today is the first day of your life.
1 MAIN MENU
2 PREFERENCES
I found that but dont want to completely disable standby if I dont have to, I'm going to try component cables and see what happens
The daily reboot cannot be turned off. You can keep changing the time of reboot but after a day or two the recorder (722 for me) will get flakey and either reboot or mess up or both. The Inactivity timer can safely be disabled. Having a non-transferring EHD connected can delay the reboot by 15 to 45 minutes doing who knows what. You take your chances with a reboot during a copy. During reboot the DVR is "shut down" and immediately restarted, eventually coming back to the channel it was on with a new copy of the guide--usually. All IMHO.
-Ken
Sounds like the TV remote's signal is the problem. The command to switch the input is seen by the 722k as a signal to go into stanedby. Try covering up the 722's sensor window and see what happens. Or if your x-box has an hdmi output, connect to the tv via that.
The 722k has to be in Dual Mode is it?.Sorry had to ask,then is the Shared View Disabled?.Menu 6-2.If all that is set correctly then your 722k is not working as it should try a reset(press the red reset button inside the right door.Good Luck!
-Ken
Daily reboot is at 3 a.m. so I dont think thats the problem
I have 3 different remotes that I use to switch the TV input (the TV remote, the dish receiver remote, and an xbox mutimedia remote), i usually just grab whichever one is closest. I'm trying different remotes to see if it's a certain one that causes the DVR to go into standby but now I'm having a hard time replicating the problem... Of course when I want it to do it it doesnt do it... I dont have an HDMI for the xbox
Yes, its in dual mode and shared view is disabled. I reset it anyways though, we'll see what happens. I'll keep you posted!
I also have this problem but for a different reason.
the inactivity setting is 100% USELESS the boxes (4 of them in 2 locations) FLAT OUT IGNORE this setting and go into standby anyway. My problem is the TIVO. if the tivo does not send a command to the box inside 3-4 hours it goes into standby and the the box STOPS responding to any commands except "power or select"
Dish is unable or unwilling to fix this problem. I have standby set to "disabled" and it flat out ignores it. 4 boxes 2 locations they have already replaced 1 box once same thing. IGNORES the setting.
is their anyway to program the tivo to send this "select" command first and wait a bit before sending its channel change request (say 10 seconds ??)
the DISH box is going to standby so the TIVO now can not change the channels IE the tivo recordings are nothing but the black screen saying your dish box is in standby press select to continue crap.
I went in and set the standby time to disabled and it flat out ignores it and stands by anyway. dish refuses to fix it.
4 different boxes all do the same things. (obviously the DISH DVR boxes wake themselves up just fine)
I am betting this is why they refuse to fix it btw. to force you to pay for more DVR boxes.
