H25-100 with SD Dish?
DMJ
16
Raleigh NC
Can I use two H25-100 receivers with a 3LNB SD dish? not sure which model but dish is about 6 years old. Obviously I'm not expecting HD pictures but that's not a problem.
If they will not play together what dish do I need to buy?
Slimline with a SL3 OR SL5 depending on what programming you have.Don't forget you will also need a power inserter.
Thanks for the quick response. I have the Total Choice Package HD.
Can you please expalin the power inserter, what is it? where does it go?
Can I upgrade the existing dish?
The PI is in the house and can go anywhere in line. I have mine in the bedroom receiver out of the way (didnt want to take up a power spot in the living room)
So do I need the SL3 or SL5 dish for Total Choice Package HD?
Does the splitter have to be indoors? Might be tricky given existing wiring.
And all the listed equipment listed above,depending on if it's an mpeg4 market the SL3 or the SL5 with kaku,power inserted,swim splitters,etc..
Hello DMJ,
One thing to remember is that even properly weatherized equipment placed outdoors will give problems in the future and will require replacement due to being outdoors. Connectors are usually the first point to check but everything outdoors should be checked to see what may be going bad and corrected as soon as possible.
