I am still learning to, believe it or not I have never used a channel editor myself.![]()
Once you do you will love it. So much faster to organize your list just the way you want it.
I used to use an app called "Channel Master". I see reference to it on the web but nothing recent, has it gone the way of the dodo bird? It seemed to support every DVB receiver I ever tried, and was easy to use and functional.
just messing around, I figured out one way. Write down the Service ID number, change it to "0" and then all the PID fields open up. edit the PID fields, then change the service ID number back to what it was and presto.I"m trying to edit the PCR PID value and try again. I go to the tp, the four audio services I had added are in my right hand window, I right click to "edit" and the only editable fields are channel name, channel type, service ID, group, scramble, factory, and audio mode. Video pid, the 3 audio PIDs and PCR pid are all greyed out and I don't know how to make them editable.
AWESOME!!!* Changed: If Polarity selection is changed from the default "AUTO" to "Horizontal" or "Vertical" for a channel search, the default setting "AUTO" will be restored after the search completion.
since I reused my existing channel list I assume this wont reflect that info?* New: Default Satellite / Transponder List for C and KU band FSS satellites with footprints in North America (as of 8.28.2012)
I'm confused on this one. If I go into the antenna setting it defaults to the sat I'm on. However effective with the 8/20 software if I go into the TP list it defaults to 61W which is the 1st sat in my list. Use to not do this and it gets very frustrating. Since I blind scan a lot I bring up a satellite, then go into the TP List to delete transponders before scanning. This adds an extra step going into the motor/antenna setup screen THEN back out and go into the TP list screen* Corrected: The Satellite in the viewing mode is selected in the Motor / Switch Setting Menu and the default satellite in the Single/Multi Satellite Search. If the Motor / Switch Setting menu is first entered, then the TP List will default to the same satellite displayed in the Activated Satellite List.
see above. I had to unplug the receiver to make it work* Changed: After future .abs updates, the unit will automatically re-boot without user needing to power cycle.
confirmed working but one comment. I scanned only the V side of 91W. When the % meter reached 28% I had scanned in my last TP (12166) yet I had to wait for it to go all the way to 100% before being done. If you are only scanning one polarity the % should (IMO) be done at 50%* Changed: If Polarity selection is changed from the default "AUTO" to "Horizontal" or "Vertical" for a channel search, the default setting "AUTO" will be restored after the search completion.
no biggie. Changed that to 720p right away* Changed: Default resolution to set to 480i (the common resolution for ED/SD/HD TVs and monitors).
.... one comment. I scanned only the V side of 91W. When the % meter reached 28% I had scanned in my last TP (12166) yet I had to wait for it to go all the way to 100% before being done. If you are only scanning one polarity the % should (IMO) be done at 50%
Putney what version are you using?
Favorites List Names, Switch / Motor settings (22khz, DiSEqC 1.0, 1.1 and 1.2) do not import, but if created in MES, they export perfectly.
