GEOSATpro microHD FAQ: Channel Editing Software
SatelliteAV
6,486
186
Roseville, CA
Tthe GEOSATpro microHD satellite receiver is supported by two editors. The basic no frills ALI Editor and the new standard in satellite editing software, MediaBox Editor Studio.
  • ALI Editor - File Types: Default Data File (.ddf), User Data File (.udf) and System File (.abs)
  • MediaBox Editor Studio v1.10_2013 by CeceLife - File Types: User Data File (.udf) and System File (.abs)
We tested many editors before selecting the MediaBox Editor Studio for the official microHD editor. The MediaBox Editor Studio is an incredibly powerful editor and with powerful editing, sorting and investigative functions not found on any other editor. We are honored to be the first North American STB to have official support and development! The program has been developed in Italian, so there are a few Italian words still in the the OSD text.
We are working with CeceLife to fully develop the editor for 100% compatibility.Attached is an English user manual based on a European release Clarke Tech Editor Studio (same as the MediaBox Editor Studio) written by Saga Lout. This guide seems very well documented and should be a great resource for MediaBox Editor Studio editor software users.
We request your feedback and patience as this incredible editor is fully implemented with the microHD. Attached is a full release version of MediaBox Editor Studio v1.10_2013 for testing. We highly recommend that you consider a donation if you use MediaBox Editor Studio. Import a .udf file saved from your microHD using the microHD STB file type. Import and merge with generic ALI channel lists created with other receivers such as the Openbox, Manhattan or Amiko products.
The software is very easy to navigate. You will be blown away with the features and functions of this editor! :D
Quick Reference:
  • The .abs file is only for firmware updates.
  • Satellite/transponder/channel lists, configuration settings, etc. are not firmware files. These files are database files.
There are two types of Database Files:
  • Default Database files (.ddf) contain the lists and configuration default settings that the receiver is reset to during a Factory Reset. MES cannot process .ddf files, but the ALI Editor can edit and produce .ddf files. It is not recommended to edit, save or export .ddf files using ALI Editor. Not all .ddf file functions are compatible when saved or exported from ALI Editor.
  • User data files (.udf) can be erased during Factory reset back to the Default Database. The User Database can be set as the Default Database in the Channel Edit menu.
  • CLARKE-TECH v1.1.pdf
  • MediaBoxEditorStudio_Setup110_2013.zip
  • 1-139w_microHD_ChList_2122013.udf
  • ALI_Editor_GEOSATpro_microHD.zip
Here is an editor I have been using for a few weeks to edit the MicroHD files and works quite well. It comes from Germany and costs about $30 USD.
Setedit.de
Locate and download SetEditHD100 ver. 1.34
For MicroHD compatibility, update to ver. 1.38 by changing to this dll in the program folder.
View attachment SetEditHD100.zip
This is a powerful editor that I found easy to use, more features than the basic pvr 800 editor. You can open two instances of the editor and merge TP or channel lists by simply dragging them from one list to the other.
Note: the down loadable un-licensed version has limited features and number of channels you can edit.
Edit: Be patient, the userdb.udf file takes a while to load if you have a lot of sats and channels like I do.
Finding that on some computers the AliEditor Configuration Settings text is incorrectly defaulted to Chip Type=M3329c and prevents the ability to modify the h.264 and displays incorrect audio settings. If your AliEditor Configuration Setting file is changing to this incorrect chipset default and not displaying Chip Type=M3601s follow these steps:
1. In the AliEditor folder open the AliEditor Configuration Settings file
2. Change text: Chip Type=M3601s
3. Save the file
4. Right-Click on the file to open the file Properties
5. Under the General tab, check mark "Read Only"
6. Click on OK to save the file properties setting
This should place the AliEditor software in the correct mode to provide advanced video and audio settings.
Reactions: dsmith0429
AZBOX Couple questions on renaming recorded shows on Micro
GEOSATpro Sending stream to TSReader ?
