Direct tv Error code ?
  • WELCOME TO THE NEW SERVER!
sportman13
352
4
What dose error code 721 Example FS South gettiing it in HD in SD is says error code 721 other sports channels the same way what is this
it means you aren't subscribed to that channel. if you are then you need to call directv and have them resend an authorization to your receivers.
here's a list of error codes :
Error Code 711- Access Card not Active
This is usually associated with a new access card. Tune to channel 377, and verify that the error code still appears?
Solution 1: Contact DirecTV to have them reactivate the card onto your DirecTV account.
Error Code 721- Service isn’t Authorized
Solution 1: Contact DirecTV to have them resend service authorizations to your receiver.
Solution 2: Contact DirecPath to have them resend service authorizations to your receiver.
Error Code 722- Service Expired
Error Code 724- Reciever ID Pairing not Received
Error Code 726- Wrong or Missing Reciever ID Number
Error Code 727- Program not Available in your Area
Error Code 731- Access Card Full
Solution 1: There is a DirecTV issue related to the VOD or Pay Per View item you ordered. Please contact DirecTV.
Error Code 733- IPPV Purchase Limit Reached
Solution 1: There are unrecovered Pay Per View charges on your DirecTV Account. Please contact DirecTV to resolve those charges.
Error Code 734- Unable to Order IPPV
Solution 1: Contact DirecTV to have them resend programming to your receiver.
Solution 2: Contact DirecPath to have them resend programming to your receiver.
Error code 736- Disabled Due to no Callbacks
Error Codes 741/742/743- PPV Data was Missing
Error Code 744- Loss of Programming
Solution 1: Reset the receiver by pressing the red reset button (located behind the door on the front of the receiver).
Error Code 746- Possible Data Corruption
Solution 2: Remove the access card from the receiver (white card inserted next to the reset button). Reset the receiver by pressing the red reset button, then reinsert the access card.
Error Code 747- Unable to Complete
User was attempting to order PPV when this error appeared or if they were attempting to use the auto-tune feature?
Solution 1: If ordering PPV, customer should contact DirecTV customer care.
Solution 2: If using auto tune, Reset the receiver by pressing the red reset button (located behind the door on the front of the receiver).
Error Code 750- Service Not Active
Solution 1: Reset the receiver using the red button (located on the behind the door on the front of the receiver).
Error Code 761- Insert your Card or MRR Service
Solution 1: Remove and Reinsert access card.
Solution 2: Remove the access card and reset the receiver using the red button (located on the behind the door on the front of the receiver). Reinsert the access card.
Error Code 762- Insert Valid Card or MRR Service
Error Code 763- Access Card Expired
Solution 1: Contact DirecTV to have them resend service authorizations to your reciever.
Solution 2: Contact DirecTV or DirecPath to get service reactivated.
Error Code 772- Acquiring Guide/Data
Error Codes 777/780/781- DOD PPV
Solution 1: If Receiver is networked via Ethernet port, please follow these:
Error code 777- see Error code 733 process map
Error code 780- see Error code 731 process map
Error code 781- see Error code 732 process map
Rey Tune to channel 377, getting the channel on FS South gettiing it in HD in SD not getting it is says error code 721 other sports channels the same way what is this
are you paying for those channels? for sure sportman1? if you are then you need to call directv or send a refresh signal by logging into your directv account.
yes it's fine. we can't help you any further sportman1. feel free to reset the HR34 but if that doesn't do it, and it probably won't, then you have to call directv. unless someone else has any other ideas i got nothing else. sorry.
Rey thanks I heard dvrhd34 Genie will have a software update What is the new Genie FW (x725) update ?
Rey,
This is the type of info we should have a Sticky made for.
If we had a Sticky, we could add all the different tips and tricks all in one place.
Rey thanks heard dvrhd34 Genie will have a software update What is the new Genie FW (x725) update ?
725 update added HD TV apps (press right arrow button) and remove OTA scanning, now only showing OTA channels that are in DirecTVs database.
twizt3dkitty someone said the new Genie FW (x725) update apparently takes care of the pop up annoying message ?
sportman1 what pop up? if you're referring to message 721 we already gave you an answer. if not then what is the pop up?
Rey
someone said the new Genie FW (x725) update apparently takes care of the pop up annoying message Direct tv tivo dvrhd34 "To record episode press R on your remote control" annoying pop up ?
Rey
I think you're right because I haven't seen that annoying pop up again. Thank you Directv for fixing this.
i see. someone else will have to help you with that.
edit: randall just gave you the answer sportman1 :)
Rey I have to call Direct tv about error code issue should I tell em to do the Genie FW (x725) update ?
no don't do that. you will get that update when is your turn. remember the updates are by waves and you will eventually get it.
