Anyone have a dp plus triplexer 175284 wiring diagram?
  • WELCOME TO THE NEW SERVER!
thfoley2
9
I would love to get a copy of the Dish pro triplexor 175284 wiring diagram.  I just had a new Dish 1000.4 installed using the Dish pro triplexor 175284 and I want to keep a diagram for reference.  I have looked online for wiring information already.
Thank you for your time and cooperation,
Thomas Foley
Sent from my iPad
Tj14foley
MattG@ DISH NETWORK said:
<img src="http://www.satelliteguys.us/attachment.php?attachmentid=69655"/>
Nice pic. But if you look closely, and since i install these all the time. If someone wanted to be anal, which i do, the sat port1 and sat port 2 on the triplexer are going to the wrong sat ports on the reciever.
So if one was to follow this diagram exatly they would have the ports on the triplexer going to the opposite sat ports.
Just an observation.
;) You're right
Hi, I have two dual tuner receivers hooked up like the diagram that MattG posted. I want to add another room. Do I use a splitter off one of the Diplexers in the attic? Or how can I use a DP311 solo receiver in this room? Thanks
You can run a wire directly from the dish LNB to the new 311.
But if install these, you know it doesn't matter. I've gone to a couple movers where the cust hooked up separators upside down, and they're working just fine. No need to split hairs.
Thanks I will do that. The installer only ran two RG6's from the dish. Thanks again for help
Standard install if that is all that is needed to cut down on expenses. Issue for future proofing is now being had cause of newer cable requirements such as for the Hopper. Direct has figured out how to use a single line but Dish is way behind on this.
