Not a bad idea. The big question, is it worth $84/year ($7/month for the extra Joey) for mirroring to TV's that I barely use?
jeremy.moritz said:Not a bad idea. The big question, is it worth $84/year ($7/month for the extra Joey) for mirroring to TV's that I barely use?
I keep on reading that no other signal can be sent over the same Coax that is bringing the signal from the Hopper to the Joey (very depressing). Can someone please take a look at this image and see if anything is possible? I don't think I can run a second coax from the Joey to my Utility because all my walls/ceilings are drywalled. So I'm wondering if there are any options out there for me to mirror my basement joey to 1 to many TV's in my house. All the COAX ends for the house go to the Utility room, but each room only has a single COAX running to it (each room also has an ethernet cable running to it also if I can do anything with that). With the old 612 I was able to backfeed the 612 output to the Utility room where I then split that signal to any of the TV's in my house that I wanted to mirror what was on the 612. I open to any and all crazy ideas
You can mirror, you just can't backfeed a rf modulated signal on the same coax the Joey/Hopper. You must use a separate coax.
3 year revival....I've mirrored a 15 or 20 joeys by backfeeding with an RF modulator using splitters instead of diplexors Haven't had any problems and the is picture is as clear as SD gets.
Mark
And that provides a high quality true HD PQ. Unless people don't mind the inherent noise of those junk RF modulators (although more expensive ones in the $200 range do provide quite good PQ and are often agile), I would go the Ethernet route, no doubt, and it is so easy, although more expensive than the cheap WallyWorld RF modulator route. However, if it is a situation where one does not need a great PQ, like an exerciser room used only an hour in the morning and you just want to monitor the news, than CHEAP NOISY crappy RF modulators would be the way to go.They also make HDMI over ethernet cable adapters. It allows you to run a high def signal over a greater distance via ethernet cable. If you google it, lots of hits will appear.
I use the Channel Master 5415 modulator
Joey has only has HDMI, NTSC (analog composite) outputs (along with stereo analog and optical digital audio outs).Can someone please help... I have the dish hopper in my living room than two joeys In bed rooms i aam trying to mirror off one joey into another room. How can i do this?
That's what I did.Joey has only has HDMI, NTSC (analog composite) outputs (along with stereo analog and optical digital audio outs).
If you want HD in the second room, you need to use an HDMI splitter.
Mine did not...I did notice a hum when listening to FM radio that was in the room though..RCA cables via adapter works also, but no HD. Dealers choice...I have read that some HDMI splitters have the side effect of removing HDCP from and HDMI signal.
Mine did not...I did notice a hum when listening to FM radio that was in the room though..RCA cables via adapter works also, but no HD. Dealers choice...![]()
Can you provide a link to the Tounge Modulater site. ThanksI'm mirroring a Joey with a blonder tounge modulater to 4 TVs and have the HDMI split three ways to three HD TVs.
