Is it All channels ?
If its all channels, its not the station.
Have you tried a different HDMI port or change HDMI Cables , could be a loose or bad connection.
Try swapping to a different HDMI port.
You sound pretty certain its not a bad D* box ... that does happen, just like everyone else.
it was hallmark and TBS mainly
we tried different HDMI ports and cables all of the connections are tight they even came out and re did the install so all new cabling splitters new boxes!!!
the problem happens all though the home
i think the DTV boxes are bad but those were replaced as well. i know it's not the t.v. since DTV is the only thing that act's up on it. dish hasn't acted up on it yet and either does spectrum
we check for firmware updates on the t.v. it kicked back that we have the newest ones so none needed. the DTV boxes haven't said they needed an update in a long time maybe that's the issue.
i also noticed that there was a whole lot of macro blocking happening on alot of the channels also
i am thinking it's something between them and the stations
signal was at 98% on all of the transponders
