Whole Home DVR Not Working, How Do I Reset Or What needs to be done?
tmiller_hockey
3
Texas
Hello,
To all you guru's out there, here's the scenario.
Everything working fine, bought a new LED TV and put it in but in the process I had to unplug everything to move it down to the other end of the wall. Now that everything is hooked back up, on my non DVR HD receiver it tells me no networked DVR's found.
I have an SWM box that plugs into my HD DVR.
I would unplug everything, then plug in the power inserter for the SWM and then go around and plug in each receiver.
Also, I had this same issue at my house right after I installed a new receiver. Make sure your receiver has the latest version of software or it will not detect the network.
Did you move around any connections on your switch/splitter?? Make sure your keep the terminators/caps on the ports not in use.
