50W Satellite
  • WELCOME TO THE NEW SERVER!
jlrpes
67
Dallas
Is anybody in Texas able to get 50W? I am able to get 58W so I assume that I can get 50W. Please help. Any help would be appreciatted.
You should be able to get it, depending on your terrain and adjacent vegetation. I live in w.Tx and can go down to at least 37.5 (have not tried anything lower.
Good luck.
Have you tried getting 50W? I live in Mckinney, TX
here's the data from Dishpointer for Mckinney TX:
Your LocationSatellite DataDish Setup Data
Latitude: 33.1972°
Longitude: -96.6398°
Name: 50W INTELSAT 1R (IS-1R)​
Distance: 38854km
Elevation: 27.3°
Azimuth (true): 117.3°
Azimuth (magn.): 113.5°
LNB Skew [?]: -48.0°
27 degrees is pretty high in the sky, unless you have some trees or buildings blocking your LOS you should be able to get it.
It appears you may be towards the edge of the footprint of 50W if I am reading the chart right. Might need a pretty well-tuned setup to pull them in.
Also, are those Claro channels ITC? The info on Lyngsat shows the Claro channels on 11050 to 11170 Ku to be encrypted.
I located in Monterrey, Mexico. I receive with a 75 cm offset, lineal LNB, and with my openbox s10.
All are encrypted, less Enlace channel.
