Hopper Remotes and My Harmony
  • WELCOME TO THE NEW SERVER!
TimR21
65
Well….I should've asked this BEFORE I ordered my Hopper and Joeys….oh well. So, if I understand correctly, the Hopper remote is an RF remote? Is there also an IR functionality? If it is RF only, I'm going to be a little bummed because I think my Logitech Harmony 900 is going to have trouble with that. It uses RF…but only from the Harmony to the IR blasters.
Hmmm….what to do?
TimR><>
Just to clarify…I realize the Hopper Remote has IR - to control TV's and other aux devices. My question is, does the Hopper itself have an IR receive port so that I can control the Hopper and DVR functions through IR - or are those functions strictly controlled by RF?
Thanks,
TimR><>
Thanks, Scott! I was typing as you were posting…..that is a HUGE relief!!!
TimR><>
When you get your receivers just go into Remote Setup and turn IR support on and you are all set. :)
Okay, this is my first post out here, but I want to clarify to just double and triple check what I'm reading. I just ordered an upgrade to my current system (DVR 612, with 2 211's) to a single Hopper and 2 Joey's. The big worry I have is I have a home theater where one of the Joey's will be and in there I have high end URC MX-880 remote that send signals to all devices (Dish Receiver, BluRay Player, Audio Receiver, and XBox 360) via IR codes. All the devices have a little IR extender that sticks to the IR sensor on the corresponding device.Is there an IR sensor on the Joey that I will be able to stick on of these IR senders to? I have to work with the HT installer to program the remote as the URC doesn't allow consumer programming, but I need to know if this is even going to be possible.From what I'm reading I will have to turn something on in the Joey, but what I haven't read anywhere yet is where/if there is even an IR sensor on the Joey box itself.Thank you and I apologize if this is somewhere else, I just couldn't find it.
Will the 21.1 remotes work with the Hopper/Joeys? Also, what is the difference between the 21.0 and 21.1 remotes? I need to know which ones to turn back in with my VIP's.
