Joey won't link
  • WELCOME TO THE NEW SERVER!
B_Kranski
852
68
Holmen, WI
Hello I have been trying to find info and hate posting new comments, but I have a two hopper, two joey set-up. when the first tech tried to install...he didn't wait till live t.v. and now that joey will not link, is there anything I can do, I have tried unplugging and plugging in, tried resetting, and noting, there should be a way for these things to go back to factory default. Any help would be appreciated, Thanks, Bill
Yeah, ready?
Unplug the joey from power.
Unplug cable from joey.
Plug joey into power.
When it boots, put in standby (hit power button).
Unplug from power.
Connect coax cable.
Plug into power.
Wait for it to boot back up, it should boot back into standby mode.
Unplug from power.
Plug into power.
Nice, right? But after the last step it may still be in standby, power button turns it on, then it should automatically start a software download and reboot again, and be active.
I have done a H/J install, and could not link a joey. The CSR also told me if the above method does not work, you can turn the hopper and Joey off for about an hour and they will automatically update and start download. I decided that we would just replace the Joey at that point. It might be worth a try before calling to have the joey replaced.
I see you are in Tampa, one of my fellow installers should have been your installer. We know not to touch the joeys until the hopper is up, I wonder why he didnt. But anyways some techs are having to go out multiple times to fix the joeys. We havnt figured out the cause although I find the above fix interesting. I have installed 5 hopper joey installs this week, and had no issues but have heard other techs struggling with joeys. We keep replacing joeys and nodes till it eventually works.... sigh
Good Luck with the reset procedures. My install tech powered up both Joeys simultaneously and they never reset or installed even after 6 hours of trying by 3 different techs. They were replaced, powered up one at a time, and installed flawlessly.
Yeah, ready?
Unplug from power.
Connect coax cable.
Plug into power.
Unplug from power.
Plug into power.
Worked like a charm, they need to teach techs this also. :) Sticky?
The one thing I learned is that live TV on the Hopper is not the best point to start hooking up Joey's. If the Hopper doesn't have a client ID the Joey's will not link to the Hopper. So to check to see if the Hopper has the Client ID:
Menu - Settings - Network setup (or just use blue shortcut) - Tests - View Counters - Then page down to the bottom - Client ID should be listed on this page.
If you don't have a Client ID DO NOT hook up the Joeys. Power off the Hopper for 10 mins then check again. Now you should have the Client ID.
Hope this helps out it has really help me and saved a second LONG install.
Good tip
I agree, good tip...this is what CSR asked me to check for when Joeys did not link.
bweiteka said:
Yeah, ready?
Unplug from power.
Connect coax cable.
Plug into power.
Unplug from power.
Plug into power.
What's your source for this proceedure?
Sent from my fingers.
Tried this and the joey still wont link
Hello,
I endured a 6 hour install effort last week on a 1 hopper / 1 Joey system. At end of day 1 hopper worked, but Joey would not connect. The next day, the installer sent another tech by, and he was sent this doc, we followed it and the Joey connected right away after doing one of the steps, don't remember which one...
The doc seems to have some good info in it, which will hopefully be helpful to you, and possibly others as well.
Good luck with it!!
Russ
  • Three Golden Rules of Hopper.doc
the hopper just won't get the client ID... I've tried resetting it, turning it off for 10, 20 minutes, one hour... leaving it on standby etc etc.
Glad to hear everything finally worked out. Let's hope that in a "near future" update the software guys will smarten the hopper up regarding network communications. I had a client ID on my hopper when my Joey would not talk to the hopper.
What do you suppose will happen when the power goes out and the Joey manages to boot up before the hopper can boot up when the power comes back on????
Have a good one.
Thing is, I was working. The installer got to my house at around 4 and the hoppers booted up fast but he left them on all the while ( his first hopper install ). I get home at 8 pm and he is frustrated as hell. I told them to go home and that I would take care of the rest. Only prob was the hopper never updated even after leaving on standby for a bit. Dunno if it has to do with the installer leaving them on for so long. Btw this is a 2 hopper 3 joey setup.
My installer did the same mistake. I tried personally the steps mentioned and it didn't fix it. It was finally fixed by the tech calling Dish and they sent out two replacement Joeys. Now all is ok.
