97w llost channels
tonguetwister_842
15
usa
Hi
I have lost several transponders on 97w.
I noticed when I tried to watch rt on 12153H.
I have tried searching with no luck.:confused:
Did it go away?:eek:
Has anyone lost it?
Thanks in advance.
I'm having trouble also, not mine but a customer that I've taken care of for several years.
The receiver puts out voltage back to the lnb & reads good signal on meter at receiver. However the unit shows zero signal and will not find anything on any transponder.
I was thinking I have a bad box, not so sure now after reading this.
My micro hd shows 45 signal and 0 quality as if I was mispionted, but all the vertical transponders are working but lost about half of horiz ones.
Hi
Has anyone lost it?
Thanks in advance.
No Problems here. RT is coming in on the MicroHd at 76% quality!
Thanks for the replys.
I will swap back the coolsat5000 to see if it is th ird or the lnbf tomorrow.
That could be an lnb on the skitz. After reading the other responses I'm back to a bad box for my problem.
I installed a new Avenger pll321s-2 lnb and new coax at the same time I hooked up the micro hd about 3 weeks ago and was working great till yesterday.
Fixed
Checking out lnbf and coax I found a bad end on the coax between the motor and the lnbf.:eek:
Replaced the end and getting all channels now.:D
Glad to hear it was an easy fix. :)
Fixed my problem as well. Turned out to be the box. Sold them a good used coolsat 6000, works like a charm.
The strange part is my sb29 read good signal & quality on both odd/even transponders at the box & had voltage back to the lnb. The old box however would not find anything & has previously worked well for years, all is good now.
