Forgot about temp and tried rotating when it was too cold out...
I've never had a problem in the cold with my rotor but I would suspect that if it was frozen then it likely tripped the thermal which should reset itself as soon as it cools down and, of course, the ice would have to melt off. Depends on the particular rotor though.
Reactions: comfortably_numb
Channel Master. A little over a year old. And for the last question only professionals are allowed on the roof so I can't answer that one.
Channel Master and year old are positives, but if ice was inside the rotor there is a good chance you might have gear damage. You will just have to wait for 33 degrees and see if it moves.
KMJC-LD in Kansas
Antennas Direct Clearview 4V
