Joey won't connect to the network.
Discussion in 'The Hopper Zone' started by jahost, Apr 22, 2012.
  1. jahost
    jahost Thread Starter Member
    Feb 2, 2006
    184
    Des Moines, IA
    One of my Hoppers is a hard wire connect to the home network. The attached Joey will not connect. I have tried all the available resets and reconnects with no luck. Any ideas?
  2. 356B
    356B Well-Known SatelliteGuys Member
    Dec 22, 2010
    837
    26
    Northern California
    If you have a password for the network did you give it to the Joey?
  3. isaacmorseMI
    isaacmorseMI SatelliteGuys Family
    May 5, 2009
    4,733
    Southwest Michigan
    A hardwired Hopper doesn't have a password.
  4. 356B
    Dec 22, 2010
    837
    26
    Northern California
    The network can.. mine does. If not I'd have the whole neighborhood cheating in on my line. When I setup the Joey it ask for authorization, but that's another story.
  5. isaacmorseMI
    May 5, 2009
    4,733
    Southwest Michigan
    Your wired network has a password? The neighborhood can't exactly steal your connection through an Ethernet cable.
  6. isaacmorseMI
    May 5, 2009
    4,733
    Southwest Michigan
    Is the Hopper that the Joey is paired to connected as well?
  7. 356B
    Dec 22, 2010
    837
    26
    Northern California
    "Your wired network has a password? The neighborhood can't exactly steal your connection through an Ethernet cable."
    I have both wired and wireless. I run a set of Apple Airports. I prefer wired but wireless is a option I often use. Hence the Joey issue....get it?
  8. sperry85
    sperry85 Member
    Aug 9, 2011
    176
    Your Joey won't connect to what exactly?
    With the hopper hard wired, it does not send that connection to the Joey's. A hopper internet connector would connect all hoppers and Joey's to the network.
    The only thing you lose by your Joey being hooked up to the network [its own IP] is DLNA support. All other content, BB@Home, DishOnDemand, and DVR content is accessed through the hopper itself.
  9. isaacmorseMI
    May 5, 2009
    4,733
    Southwest Michigan
    Yes, it does.
  10. sperry85
    sperry85 Member
    Aug 9, 2011
    176
    Be a little more specific.
    No a hopper will not connect your Joey to your network with the Joey receiving its own IP address on your network. I have not tried this myself, but it has been talked about in length that the Joey must have its own connection to the network for dlna.
    And a Hopper Internet Connector is the only way to connect all receivers to the network without hard wiring Ethernet to each one, or using a wireless adaptor/bridge.
  11. isaacmorseMI
    May 5, 2009
    4,733
    Southwest Michigan
    Yes for DLNA it must have it's own connection, unless that was resolved in S208/S260. But for all other uses a hardwired Hopper is best.
  12. sparc
    sparc Active SatelliteGuys Member
    Jul 24, 2006
    1,706
    7
    The HIC is just fine for hardwiring purposes. Plus it's less troubleshooting for DLNA purposes. One connection point.
    At this point, just about anyone doing hardwiring should just get it in the original install for free. At minimum as a backup in the event your network changes later on.
  13. jahost
    Feb 2, 2006
    184
    Des Moines, IA
    I guess I don't really have a problem. I assumed that since the Joey said "connection failed" on the broadband that I wouldn't be able to access the blockbuster movies. That does not seem to be the case. Sorry!
VigLink badge
Sucuri
