Hi guys, I am new to posting to the forums and a bit late on this topic, but Dish if you are listening (which I see a rep is) -- PLEASE keep the option open in the future to support more than 1 USB OTA tuner. I have 4 OTA ATSC tuners in my PC and it handles it great. From what I can tell of the processing speed and abilities of the hopper, I'm willing to bet it can handle more than 1 OTA tuner. I realize there are limited USB ports, but for those of us who will use a powered USB hub, please work on supporting at least 2 OTA tuners and preferably 4. If you have to release your own brand of USB OTA tuner, design one that supports 2 tuners per stick and allow at least 2 sticks to be attached to the system. When I first read the specs on the hopper, I was pretty disappointed that it only had 3 tuners. 4 would be perfect IMO, especially if you dedicate one to the primetime anytime feature. My ideal system would have 4 Sat tuners and at least 2 OTA tuners. Most often I run into programming conflicts with those annoying shows that insist on starting and ending 5 minutes late. The scheduler is then technically "busy" so it won't start on an event that starts at the normal "top of the hour" time.Based on Scott's previous info, each hopper can support one USB OTA tuner. If you need more than one OTA tuner, you can plug in the additional one on a second hopper.
Also, on an unrelated note - perhaps someone has the answer. Does the hopper still have to reboot once every 24h like the 722 does? And does it still have a hard time downloading the guide sometimes if you keep the tuners busy? If so, why not allow the option for it to download the guide updates continuously over the internet?
I'm going to guess the Hopper only has USB 2.0 ports, even tho USB 3.0 has been around for 2 years now?
I actually have no use for the Joeys. I'm in a single user home and long ago took the trouble to run HDMI split out to 5 TV's around the house. I just record an insane amount of stuff.
