Hey everyone, Take a look at this. The often heard of never seen Model A0 2027 birdview off set spoon feed dish. I bought this 7 or 8 months ago. I had plans of cleaning it up and useing it. But now I realize I've got to many irons in the fire and ain't never gone'a get around to fixing it up. First off some facts about this dish. Unlike all other birdview dishes this one is not made of spunaluminum. This dish is made out of pressed steel. Much like the same material that the small dish or direct tv dishes are made out of. The back plate that the motor mounts on is a seperate piece that bolts on, not molded into the dish like on the aluminum dish. This dish is not without its dents and dinks. The guy I bought it off of his father bought it in 1984 and never installed it. So its spent it's entire life leaned up against a building. The reflector surface is fine except for about 5 small dents that looked like hail dents. I kinda fixed them but they need alittle more TLC . The reflector surface is slightly dented on the bottom were the feed horn support arms bolts on. The lip around the dish is bent in several places from the dish being rolled around and moved etc. The dish motor is a 37 to 1 gear ratio and still has the original read sensor. The LNB feed horn is an amazeing 15 inchs across. The dish is approx 8 ft 6in by 7ft 2in. If you have any questions are want any more pics just let me know. I would like to sell or trade this if possible so PM me if interested.
