Got a Linkbox 8000 HD Local? Please help...
  • WELCOME TO THE NEW SERVER!
iBoston
2,604
2,151
North Central
I got my secondary receiver. Everything seems good except....
When i turn it off, and turn it back on, it does not return to the station i left it on. Both satellite receivers I've used previously remembers, so when i turn it back on, it starts showing the station on the satellite was left at when it was turned off.
What the heck is going on?
The issue is even worse than first thought. It also seems to forget my satellite position for USALS! I seem to have to re-type the lat/long in everytime i restart.
I am running MainCode v6.0.0
That box was designed for the eye patch group. So it really don't care about USALS.
I reverted back to 512 and it is working now. Phew... I was nervous. I had upgraded to 600 and it started doing this. Ill stay away from 600 for a bit.
Since I owned a Linkbox 8000HDLocal , I sent LinkboxUSA an e-mail explaining some user were having issues with the latest v600 update. Here is a c/p of their answer:
"We tried download 8000HD Local V600 version and upgraded from current V512 version for several units we have and found works fine. It returned to the last channel watched after turn the unit off and on. Also USALS program keep well as programmed. Please let them check again. Recommend to select "All code+ Boot code" at upgrade and rescan again."
Regards,Tech
Regards,Tech
Thank you.. Ill give it another go...
Hey, do you have issues where it removes the 'moving dish' when its still moving, and then never brings in the channel your at, unless you change to another channel on that satellite and then return??? Seems to be an issue when the dish has to move more than 15-20 degrees.
What is the v600 supposed to fix? Sometimes it's best to not upgrade unless there is some problem you have that the software upgrade is supposed to fix.
Reactions: FaT Air
iBoston:
I don't have a motor, all my dishes are fixed using 1.0 and 1.1 Diseqcs. I will forward your concern to them. I will like to mention that everyone can send e-mail directly to them. I'm just passing the information. Here is their web page. Their E-mail and phone number is there. They usually answer every e-mail I sent.
http://www.linkboxusa.com/contactus.htm
bigg t:
You can also forward your question about what was fix or updated to them as well. The v600 doesnt include any release note.
Regards,
Here is LinkboxUSA answer to your question:
Hi,Definitely the problems can be happened if upgrade to new version with old version back up data.Therefore have to factory setting the unit if downloaded Main or All data. If download All & Boot code, we understand clear all old programmed channels.Have to rescan again with new updated version. We had similar problem at our test bench before and found out that if factory setting, it cleared.
Regards,Tech
Regards,Tech
Does that mean i loose all my channels??? I have to rescan, and retype all my favorites?!?!!? Wow.. Well, ill email them directly.. Thank you for that...
Also, is it ME, or does the terrestrial receiver stink??? I have three devices that pull my channels. The Linkbox won't pull them in very well.. What was the point of me buying the LOCAL if it cannot successfully pull in the LOCAL?!?!!?
You're Welcome!! I will move aside so you can go directly and talk to them. Good luck!!
