Hopper With Sling S515 Update Is Here
I don't see a play option in the guide for vod programs. I even looked to see what shows are vod and I go to the guide and see those episodes yet nothing tells me I can instantly watch it
What am I missing? Guide not updated perhaps? I am on 515
But I don't see it anywhere I figure 120 and 182 would show it. Hum...I'm blind
If anyone sees it post screenshot? But could my guide just need to refresh I just got the build maybe its not all showing yet.
I FINALLY GOT S515 SOFTWARE!!!! :grinbounce
All my joeys and super joey work just fine and I love the green caption button -that I suggested. It works just the way I said it should: one button push on /off. I'm finally glad that the sub channel ota timers work again,even though the early /late feature still doesn't work. I still wish that DISH would enable the "add the ota station "option . It has been "coming soon" since 2012 and it is way overdue. All in all to me , it looks like a good software update.:hatsoff
Same here, agree 100%. Now if they fix the OTA mappings here in Vegas I'm all set to be able to record MyTV and Cozi again like I was before 506. So the issue is not completely fixed for me yet.
I was seriously contemplating dropping the H/SJ/J and using 1 VIP211k with EHD on welcome pack for one TV(till contract runs up) and signing up with Tivo with or without cable for the other TV's.
Reactions: MikeD-C05
Nothing different on 122 either no play and iuf I hit select I get the usual options to record etc
OK I did a switch test and it shows!!
And they really changed that it used to take forever it took a minute
when are they going to add the ota station option i wish they would turn it on.
thanks
I finally got S515 last night... the first software update since July.
One thing we've wanted for a long time is an easy way to turn captions on and off and we have it now! Just hit the green button. Thanks, Dish!
There are several other noticeable changes with this update. Will have to see how well I like them.
Larry
SF
S507,S508,S509,S510, S511, S513 were all betas that probably were never released, because the team discovered bugs before public release to us. Or they crapped so many HWS that they were pulled after the first release.
I'm still on 513.
Like Charlie Brown says, "I got a Rock!"
So far I discovered that the ota sub channel timers work again for namebased recording. The early /late feature for ota channels still don't. There is the new added feature to binge watch as they call it. Meaning when one program ends and you have another one in your folders , it will bring that one up if you press the play button at the end of the first recording. Closed captions are now with a push on of the green button and push again off with the same button -like I suggested months ago. This is a nice improvement over the many button pushes it took before. Also in the guide there are play symbols if the show is also on demand. You push the play button and it brings up that option to watch it on demand. This is cool if you come on to the show in the guide and it is already in the middle of it and you want to watch from the start. You simply select the on demand version and Viola you are all set.
Ok, I have been lurking here because I'm wondering if I am the only one seeing all the bugs since the (ahem) 'improvements'.
First off, the Joeys are slooooooooooooow since 515 hit. We have a HWS, Super Joey and two regular Joeys. The HWS and the Super are very fast, regular Joeys have been at a crawl since the update. Talking guide scrolling, apps.
The search bug where you move back to the letters to change the entry and the cursor automatically goes to 'P' and clears out the search text is back. They had fixed this last summer and now it is back again.
The rentals have been extremely wonky since the update - black screens, downloads that are 'expired' right away. Pulling the plug fixes them again, but should I really need to do this?
And the strangest of all - a random black dot in the middle of the screen on the very bottom on the HWS only - no, I'm not crazy. This was not there before the update - believe me, I would have noticed. A hard reset fixes. Only shows up once in a while - I've tried different HTML cables, ports, etc. Definitely coming from the HWS and new oddity. Not there for other HTML sources so not the TV. Defective box? Maybe, but I can tell you it worked flawlessly until this update.
I wouldn't even know where to go with this stuff. We know how scary CSRs can be.
I like the 'play' option from the guide BTW for On Demand. But wow, why do they have to break stuff when they give us something new?
Sent from my iPad using Tapatalk
