My grill of three gas cylinders.
This is how I myself make a barbecue from three gas cylinders.Your attention will be about 200 photos.The initial and final process.
-I watched all our craftsmen on YouTube, well done guys. Although there is a lot of plagiarism, but everyone does it in his own way. I have some plagiarism too, but I will try to bring something different.
-I liked these two stories more.
I had three gas cylinders of 50 liters each. Only gathering dust in the garage. And in the winter of this year, in one month, I handed over such a unit.
On the right, this is a furnace, plus a smoke generator is inserted there. You can fry and cook various soups from above.
In the middle, a brazier. For frying a shish kebab, a barbecue, hot-smoked fish, meat, vegetables.
On the left, cold smoked for meat and fish.
There were few welding works with the brazier, mostly drilled, cut iron corners and everything was assembled on various bolts. I took the removable hinges for the doors. At any moment the door can be removed.
Precautionary measures
When working with a brazier from a cylinder, you should think about how to protect yourself from an explosion. Even if you completely unscrew the valve and there is no gas inside, you should not hurry to cut the metal. Despite the fact that the pressure in the cylinder is identical with the atmospheric pressure, there are still hazardous substances inside: condensates, propane.
Cut the hacksaw 1 or 2 studs, remove them and unscrew the valve in the cylinder
-Invert the cylinder so that the condensate remains. Put the iron container to drain the condensate .. Then ignite the condensate.
- we fill in water in a cylinder and we leave for 1-2 days.
-after 2 days for reinsurance, bring the fire to the balloon at a distance. It didn’t jerk, it means everything is great. You can cut it, but you can make the first cut with filled water
-and it was an ancient foot sewing machine was with me. I took it for the basis of the whole construction. I cut off the extra details. They also went into business. Made the grate for the furnace.
-Drawn a picture of what my grill will look like.
I took a metal corner from the old army bed. I drilled it and screwed it to the bed of the sewing machine. So this kind of base turned out to be where the two cylinders would lie and fixed the side of the cylinder for the stove.
-bought in the store these 2 wheels. One wheel cost $ 5
I turned the bed over and did everything to fix the axle with the wheels. So it happened.
Continuing in the evening.
