SatDreamGR on Edison OS MIO 4K
  • WELCOME TO THE NEW SERVER!
Flu is gone, BUT, I now have a bit of active bronchitis. Though it's been cold and damp, and snow/ice storm after storm in Michigan for well over a week, and another coming tonight to bring maybe 8". I have the chronic bronchitis form of COPD anyway. So, it's not that surprising that my flu went into active bronchitis. So far I only really have the middling cough (hope it doesn't go into the gut crunching version), and feeling a bit drained.
primestar31,
Glad to read you're on the mend. I still have an occasional cough from the flu i had 3 weeks ago.
Its more annoying than anything.
John
Reactions: primestar31
Hi All,
I have yet another question to ask concerning the Edision OS Mio 4k.
How do I go about manually adding a transponder to scan ?
Thanks in advance.
John
Reactions: SDA_FL_USA
Hi All,
Thanks in advance.
John
use signal finder/ User defined transponder and enter the perameters. when you get signal press ok to scan. There was a plugin called ts-satellite editor at one time for adding transponders to a custom satellites xml placed in etc/enigma2 but I just looked in downloadable plugins and did not see it.
How I add transponders to my custom satellites xml is manually add them by opening the xml file with wordpad.Just have to be careful.
edit: ts-Sateditor download plugins under extensions. Will need a custom satellite xml in etc/enigma2.
help all, i think i just bricked my mio4k, loaded satdreamgr onto a usb stick, put into mio, went thru menus, loaded satdreamgr, said it was done, press exet to return to menu, then went thru menus to multiboot , selected setup_2, asked to conferm loading setup_2, selected yes, started to reboot, now stuck on boot, powered down, then back on, still stuck on boot, , tv screen shows edision screen , mio box says boot, i did make the backup per brian's directions, but dont know to use the backup since it is stuck in boot mode, thanks , looking forward to resolve, tom
It's not bricked. Bring up the Webif screen in your internet browser, and go into the video settings and set it to match your tv set. Just type its IP address into your browser, and hit enter.
Or, plug it into any other tv set you have around there, and see if it comes up, and change it there.
thanks for info, but webif wont connect to mio, plus i have an inage on the tv screen, which shows the edision splash screen, ant the mio box screen stays at boot
It's still likely the tv resolution. Try connecting the Mio to another tv set, and hope this one will bring up the screen. Do NOT start reloading images and stuff.
Reactions: Titanium
I agree, the resolution or refresh rate is not supported by your TV or using an old HDMI cable that doesn't support handshake.
If you dont have another TV, try a computer monitor.
If that doesn't work, will try a force image install using OpenPLI or OpenVIX.
ok, will have to try a little later and have the bride move it to the big tv, it has been working on this small one fine, but will try the easy one first, hopefully will be able to take pic this thim, no luck on pic.
i did the backup per the instructions when i got the box, so i somehow with direction reload the orginal opena.tv from the backup usb i made. thanks both brian and primstar31( hope i got it right) , my 70 + year old brain is getting fogggy. edit, from now on, if it an't broke i wont fix it, ( ae1th).
So it's now working with the original image? Just leave it on that for now, and do your setups and get it working.
I HIGHLY suggest the very first thing you do is connect it to your network, and make sure you can get to it via the WebIF screen. Once that's working for sure, you should be all set no matter what.
primestar, no it is not working yet, i orginaly did the backup when it was new, i dont know how to use the orginal backup on the usb to reboot it, need direction help to do it,.
Have you tried it on another tv or monitor yet? I'd do that before the following instructions.
Read this post, and follow the directions, it should be the same, just ignore the part about "downloading", and use the image on your backup drive: SatDreamGR on Edison OS MIO 4K
Reactions: comfortably_numb
primestar31, i will follow the newer directions per the suggester per brian that u refferenced to.,
brian openatv is what was shipped with the mio, i would like to install that again, or would like to the new satdreamgr n.a. upgrade if it is downloadable somewhere.
moved the mio to another 48 in tv, with new hdmi cable, still same problen , tv screen shows " edision " on the tv screen ant the mio led screen says " boot " and freezes there.
Reactions: Titanium
Hello mememeth
I wonder is multiboot is stock on a empty slat, this is what you do disconnect the power from the receiver give it about 1 minute and connect the power back to the receiver, while the receiver is powering up press the menu key on the remote a few times fast, a window is going to come on and it is going to ask which slat you want the receiver to boot up with, if you still have the Open ATV image as the original image choose slat 1, use the side arrow keys to move the slats, then press OK on the remote.
Hope this helps.
Regards.
Chewie
Question for those using the SatDreamGR image; when setting up a motorized USALS dish, do you have to input the "home" coordinates for each satellite? (not the satellite's position, the dish's position). Suspect I am overlooking something in initial setup...
