Two second freeze
Andrew Sullivan
94
33
Arizona
For the past two weeks my picture will freeze for 2 seconds then start right up again. It does this several times a day, live or recorded material. Today I unplugged everything and did a cold reboot with my HS17. Didn't help. Anybody have a possible fix?
Weird. Sounds like you may have to replace the HS17.
Did you reboot your client also?
If you rewind do you see the pause in the same place you saw it before? If so, it is probably a problem elsewhere (LNB or cable) if not it could be a sign the hard drive in your HS17 is failing.
