Best Channels in FTA [C/Ku]
  • WELCOME TO THE NEW SERVER!
DiogoFer
California
Hello,
I'm planning to buy a big dish (8' solid, motorized) in the LA region, with a Dual C/Ku LNB. That being said, what are in your opinion the best channels that can be received for free in the region? I speak English, Spanish and Portuguese, so anything in those three languages is fine. I've taken a look at Lyngsat and noticed I could get some Virgin Islands affiliates for NBC and FOX, are they worth the while? What about Canadian TV, could I get CBC and CTV?
Yes the Caribbean mux on 99 is good for an 8' dish, and CTV on 107. 103Ku is good to have as well. 127 is NASA TV.. certainly a must-have. :) 97 has a lot of Spanish TV as well as CBS english too. Lots to pick from but you'll be using the motor for sure.
I see this is your first post. Welcome to the forum!
-C.
Thanks for the warm welcome! What about C-SPAN, is it possible to receive it digitally or are we limited to the Analog broadcast? With the 8' Dish, could I receive it properly? Another question I have is to what exactly is broadcasted on the satellite versions of, for example, the 103W NBC Channels - Are they 24/7? Do they have ads? Or really, are they just feeds for local affiliates?
Here is a site providing program info for some 100+ FTA channels. Set your time zone and format.
http://ftalistings.com/
Reactions: raydio
Depending on how far East you have unobstructed view of the arc, you might be able to get 55.5W and 58W. 55.5W has many Latin American channels if I remember correctly (some in Spanish, some in Portuguese).
As for the LNB, are you talking of a combo C/Ku LNBF, or a more sophisticated feedhorn like a Corotor with C and Ku LNBs? The combo LNBF is a compromise and in many cases does not give good results on Ku. Another option might be a good C-band LNBF and a cheap Ku LNBF mounted to the side of it.
