What conduit end connector should I use?
StevenMark
33
When using conduit for cable runs from the dish antenna, what end connectors do you use on the conduit? I will be using 1-inch non-metallic flexible conduit with twin RG-6 with ground.
careful flexable conduit sucks for pulling...and you better estimate how many degrees of bend in it....If the walls are closed up you may not be able to pull much or far.
