Loose 82 & 91 birds when sw21 is attached
Keith Johnson
canada
Hi
When each wired separately to the receiver I have 90% on 91 & 87% on 82, each on their own dish. I Installed a new sw21 inline to get both sats on one receiver & both signals disappear.. There is no options to pick lnb 1,2 0r any lnb. Do I need to reprogram the 9400 receiver.
Do you have a seperator installed?
Make sure to run a check switch.
Open menu, system setup, point dish, check switch, test.
A correction on the check switch now that I have a 9400 in front of me:
Open menu, system setup, installation, point dish, check switch, test.
