1 GHZ RG6 Cable?
reubenray
1,570
1,360
Bella Vista, Arkansas
While prepping my cables for setting up a tripod for my motorhome I found the cable for this is labelled as 1 ghz. What I have read 1 ghz cables are used for cable TV.
Will this work with a Wally?
Probably. It probably has greater bandwidth than they tested it at.
I assume this is not decades old coax.
Would Newmar actually chisel on coax? I'm having a hard time with that.
Actually, wouldn't it be more accurate to ask if that coax would work with the particular LNB you have?
If it's decent RG6 I wouldn't worry about it, it will probably be fine. It might have only been sweep tested to 1GHz but will likely do higher.
Even a good RG-59 that's 20 gauge will work, the cheap stuff that's 22 gauge causes issues.
It is 18 gauge. I was just surprised that this cable was 1 ghz where other cables are labelled as 3 ghz in the Newmar motorhome in other locations. I could not find any writing on the other two cables in that compartment. I guess I am lucky that I did not decide to go the Hopper 3 route being it requires 3 ghz cabling.
Not necessarily so, I placed the cable that my Hopper 1 and now 3 works on in June, 1987. They have worked perfectly on that cable since March, 2012. I seriously doubt that it was swept to 3 ghz, I'm not even sure it is RG-6 but the copper is heavier than RG-59.
This will absolutely work as a wally is a rebranded 211 with a different UI. However, it would behoove you too just switch to 3ghz double braided@75ohms to support a hopper and Joey system.
This would not be impossible, but it would be very hard to do this in a motorhome. Plus pulling my H3 and J3 out of the house is not something I want to do. These do the bulk of my recording while we travel and the H3 is in an entertainment center and not easy to access.
Skipping ahead 12 or 24 hours on the Electronic Program Guide
Hybrid lnb
