10 foot solid perfoated Unimesh dish
Comptech
3,692
2,856
Travelers Rest SC
Ok this has been on here before and the Ku dish is spoken for. That is going away next weekend. The 10 foot unimesh solid perforateded is still for sale. I am getting takers, but takers are what I am getting. I have gone to $300 for the dish with a ortho feed, 3 movers, norsat lnb's and two tbs tuners. Only contact me if you are willlig to give back a few bucks of the thousand I have invested. I can demo it before removal if needed.
I lost another potential person am I wrong for asking 300 bucks for a like new 10 foot Unimesh perforated with 3 movers and a dual feed with high end Norsat lnb's and two PC tuners? Also two mopdded 4x8 powered switches?
  • Sad
Reactions: FTA4PA
I have what we need here already but for someone interested in a dish I think it is a great price for a 10ft plus all the extras. Hopefully somebody will see it available and grab it.
Reactions: freddylq
That's a great price and a few years ago I would have certainly taken you up on it. I drove to Columbia and picked up a 7½ foot Unimesh in March 2017. Since then the trees on the adjacent property to the west have gotten tall enough that I'm losing line of sight for several satellites. That Unimesh dish now has a dual output prime focus Ku LNBF installed and usually stays parked on G16 at 99W for PBS. Surely someone will get it from you.
Reactions: FTA4PA
Lets see if I can post a picture here, tried in PM but would not work. Here we go.
Don't ming that Ku dish, that was a loaner to see if I could get over the trees. and it did, set up the brand new 1o foot unimesh and the andrews 1.2 and all was good.
Reactions: FTA4PA
That picyure shows how wooded I am in the winter, but was still able to see 87W to 125W. After Helene up here it held up fine and now can see to 133w thanks to the trees sacrificing themselves to the satellite guys!
  • Love
Reactions: freddylq and FTA4PA
$300 is a bargain... While I already have a BUD (plus a spare one), the norsat and dish movers are something I would be interested in - that alone is well worth the cost. But that would mean driving all the way from CT to SC and back, and I can't even imagine how expensive it would be to ship that stuff.
Honestly i'm as shocked as you are that no one has jumped on the oportunity yet
I have one member on here interested here.He thinks it's a mesh dish and I told him it is perforated steel dish. Could some of you reassure on here that their is a big difference between the two. Thanks.
A Perforated antenna will hold its shape much better over time, and when compared to a mesh antenna of the same diameter, the perforated type normally outperforms mesh at the time of initial installation, and most certainly after a number of years. A perf is made of sheets of solid metal that have been perforated, and when it is placed upon a frame, is much more rigid and will stay that way for decades under normal circumstances. Mesh antennas, depending upon how reinforced, can often lose their shape quite easily. Sectional (typically 4 panel sections) mesh type have been known to "clam shell" in high winds, making them nearly impossible to repair.
A knockdown type antenna such as the Orbitron SX series, is built with multiple ribs, which attach to a perimeter section, and also the center of the antenna. When fitted with their "Micromesh" product, they work quite acceptably on Ku-band. As you assemble such an antenna, it is constantly reinforced through the placement of single mesh panels into grooved slots, with many models securing the mesh with steel mounting J hooks as well as mesh clips tapped into the back of the mesh. Some models also had something called Edge trim, which secured the outside of the mesh to the frame. Despite all of these precautions, the mesh can and usually does get damaged over time. Orbitron closed its doors 25 years ago, and there is no source of equivalent replacement mesh in today's market. They will probably work pretty well on C-band, but C/Ku can be dicey.
Jumping back to the Perforated antenna, look at the construction of both the antenna that the OP is selling, and something like the Winegard Pinnacle Perf. Ask anyone that has been in the big dish satellite antenna business for any length of time, and you should hear confirmation that these antennas simply outperform others of similar diameter, even when compared to mesh models from the same manufacturer.
You will need either a trailer or an open pickup truck bed to easily transport panels from a perf type antenna. That is the only disadvantage that I can see, but it is the only way I can suggest hauling it from South Carolina to the potential purchaser's location. The price is a steal, and it is doubtful that you will ever find a comparable setup anytime in the future. Grab it while it is available, because the system is still worth several times what is being asked.
C and Ku Band equipment for sale
RCN on SES 6 (40.5°W)
