1000.2 EA, aka EA Twin, aka EA.2 Settings
bwcombs
Thread Starter
Aug 1, 2005
So with my newer dish that doesn't appear to be specifically listed on dishpointer.com; should 1000.4 settings work for my newer 1000.2 EA setup? I'm asking because on initial setup I've had difficulty getting anything on 72.7, but repeated success on 61.5 using 1000.4 settings. Unfortunately due to rain, I've not had time to continue troubleshooting. There doesn't seem to be extensive information out there yet on my newer 1000.2 EA Twin setup.
primestar31
8,811
5,228
Beta Omicron Delta III
The 1000.2 settings for EA will be the same as the older 3-lnb 1000.4 dish. You need sats 61.5 and 72.7. You just won't need an lnb for 77w.
uriel0818
37
Thats true. .2 ea settings are the same as .4. You might need to mess with the elevation about a degree up OR down in some cases though
navychop
Member of the Month - July 2014!
49,826
14,734
Northern VA
If 61.5 is ok, I'm thinking skew may be just a tad off.
