2nd Dish
Tac
299
5
Erie, PA
Is there any way to use a D* dish that is disconnected, as a 2nd dish pointing @ 61.5 to receive E* programming.?
If its a 18" dish with no switches built in (like the phase iii does), yes you can. I think you can use the LNB, you would have to get a SW21 switch.
It should work for legacy stuff, but if you need to upgrade your LNBF to DishPro I don't believe the LNBF will fit.
Will the 322 work with one one cable attached to it?
Echostar to Bid for MVDDS Spectrum
