Receiver is "Searching for signal on: Satellite in 2".
So far I have swapped cables. Put both dish inputs into receiver input 1, both worked. Dish/LNB is ok. I have done a reset from the setup menu and reset power.
When I did the swap, both inputs worked for about 3-4 minutes, then problem resumed.
I checked siganl strength and only on transponder 20 is this problem evident. Input 1 shows a strong siganl, while input 2 shows none. Other transponders show both strong or both "no signal".
