3/3/2010 1:51pm - Uplink Activity Report - 97 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/4/2010 2:13pm - 97 changes
Uplink Comparison Range: 03/03/2010 01:32P - 03/03/2010 01:51P
Channel Additions:
5282(19) - KTVE [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(El Dorado, AR-NBC)
7813(43) - KEJB [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(El Dorado, AR-MY)
7816(12) - KETZ [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(El Dorado, AR-PBS)
7604(26) - KGCW [MPEG4 SD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Burlington, IA-CW)
5192(6) - KWQC [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Davenport, IA-NBC)
5193(18) - KLJB [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Davenport, IA-FOX)
7607(36) - KQIN [MPEG4 SD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Davenport, IA-PBS)
9264(8) - WSIU [MPEG4 SD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Carbondale, IL-PBS)
5150(3) - WSIL [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Harrisburg, IL-ABC)
9262(27) - WTCT [MPEG4 SD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Marion, IL-REL)
5190(8) - WQAD [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Moline, IL-ABC)
7606(24) - WQPT [MPEG4 SD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Moline, IL-PBS)
5191(4) - WHBF [MPEG4 HD] added to EchoStar8 77W TP 06 ConUS beam (NA)(Rock Island, IL-CBS)
5152(6) - WPSD [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Paducah, KY-NBC)
9259(49) - WDKA [MPEG4 SD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Paducah, KY-MY)
9261(29) - WKPD [MPEG4 SD] added to EchoStar8 77W TP 24 ConUS beam (NA)(Paducah, KY-PBS)
5280(11) - KAQY [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(Columbia, LA-ABC)
5282(7) - KPLC [MPEG4 HD] added to EchoStar8 77W TP 10 ConUS beam (NA)(Lake Charles, LA-NBC)
5283(29) - KVHP [MPEG4 HD] added to EchoStar8 77W TP 10 ConUS beam (NA)(Lake Charles, LA-FOX)
5285(18) - KLTL [MPEG4 HD] added to EchoStar8 77W TP 10 ConUS beam (NA)(Lake Charles, LA-PBS)
5281(8) - KNOE [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(Monroe, LA-CBS)
7814(13) - KLTM [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(Monroe, LA-PBS)
5283(14) - KARD [MPEG4 HD] added to EchoStar8 77W TP 14 ConUS beam (NA)(West Monroe, LA-FOX)
7815(39) - KMCT [MPEG4 SD] added to EchoStar8 77W TP 14 ConUS beam (NA)(West Monroe, LA-IND)
5270 - WGGB [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-ABC)
5272(22) - WWLP [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-NBC)
5273 - WGBY [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-PBS)
5274 - WGGBD [MPEG4 HD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-FOX)
6531(67) - WSHM [MPEG4 SD] added to EchoStar8 77W TP 22 ConUS beam (NA)(Springfield, MA-CBS)
5151(12) - KFVS [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Cape Girardeau, MO-CBS)
5153(23) - KBSI [MPEG4 HD] added to EchoStar8 77W TP 18 ConUS beam (NA)(Cape Girardeau, MO-FOX)
8137(40) - WPCB [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Greensburg, PA-REL)
8135(19) - WPCW [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Jeannette, PA-CW)
6477(4) - WTAE [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-ABC)
6478(2) - KDKA [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-CBS)
6479(11) - WPXI [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-NBC)
6480(53) - WPGH [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-FOX)
8134(22) - WPMY [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-MY)
8136(13) - WQED [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-PBS)
8142(16) - WQEX [MPEG4 SD] added to EchoStar8 77W TP 02 ConUS beam (NA)(Pittsburgh, PA-SHOP)
6877 - UP29 [MPEG4 HD] added to EchoStar8 77W TP 30 ConUS beam (NA)
Channel Removals:
7873 - KOZJ (A) (H) removed from Echostar12 61.5W TP 13 Spotbeam 15(Joplin, MO-PBS)
550 - OLYM1 (A) removed from EchoStar11 110W TP 24 ConUS beam
550 - OLYM1 (A) removed from Nimiq5 72.7W TP 29 ConUS beam
551 - OLYM2 (A) removed from EchoStar7 119W TP 18 ConUS beam
551 - OLYM2 (A) removed from Nimiq5 72.7W TP 29 ConUS beam
552 - OLYM3 (A) removed from EchoStar7 119W TP 18 ConUS beam
552 - OLYM3 (A) removed from Nimiq5 72.7W TP 29 ConUS beam
5948 - TP208 (A) (H) removed from EchoStar3 61.5W TP 32 ConUS beam
5950 - TP210 (NA) removed from EchoStar3 61.5W TP 32 ConUS beam
19211 - OTV2 (A) (H) removed from Anik F3 118.7W TP 13 ConUS beam
19222 - IWINO (A) removed from EchoStar7 119W TP 13 ConUS beam
Channel Moves:
374 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam (A)
4271 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam (A) (H)
5304 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam (A) (H)
9531 - DNFYI [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to EchoStar11 110W TP 13 ConUS beam (NA)
9531 - DNFYI [MPEG4 HD] moved from EchoStar3 61.5W TP 20 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (NA)
Channel Package Flag Changes:
192 - ID [MPEG2 SD] - EchoStar11 110W TP 09 ConUS beam changed package flags (A)
192 - ID [MPEG4 SD] - Nimiq5 72.7W TP 07 ConUS beam changed package flags (A)
581 - JUS1 [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
590 - MAKTV [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed to hidden from non-subs (A) (H)
591 - LAMNR [MPEG2 SD] - Anik F3 118.7W TP 07 ConUS beam changed to hidden from non-subs (A) (H)
592 - ZHIVI [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed to hidden from non-subs (A) (H)
593 - RLIFE [MPEG2 SD] - Anik F3 118.7W TP 01 ConUS beam changed to hidden from non-subs (A) (H)
608 - ITVN [MPEG2 SD] - EchoStar3 61.5W TP 29 ConUS beam changed package flags (A)
675 - TVJPN [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to hidden from non-subs (A) (H)
727 - VIDIT [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
728 - RAI [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
730 - RAINW [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
736 - ITVN [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
738 - CTC [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed to hidden from non-subs (A) (H)
742 - ISRL1 [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed to hidden from non-subs (A) (H)
743 - GLI [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to hidden from non-subs (A) (H)
784 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
785 - VKAIR [MPEG2 SD] - Anik F3 118.7W TP 20 ConUS beam changed to hidden from non-subs (A) (H)
786 - PEOPL [MPEG2 SD] - Anik F3 118.7W TP 01 ConUS beam changed to hidden from non-subs (A) (H)
900 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
900 - EURNS [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
901 - EURNS [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
901 - EURNS [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
908 - RAD60 [MPEG AUDIO] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
909 - RADIT [MPEG AUDIO] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
910 - RAIRD [MPEG AUDIO] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
Channel Renames:
481 - PPV - EchoStar11 110W TP 14 ConUS beam renamed to NUDE (A)
481 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
482 - PPV - EchoStar7 119W TP 16 ConUS beam renamed to NUDE (A)
482 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
483 - PPV - EchoStar11 110W TP 16 ConUS beam renamed to NUDE (A)
483 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
484 - PPV - EchoStar11 110W TP 02 ConUS beam renamed to NUDE (A)
484 - PPV - Nimiq5 72.7W TP 07 ConUS beam renamed to NUDE (A)
Transponder Changes:
EchoStar8 77W TP 02 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 06 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 10 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 14 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 22 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar8 77W TP 30 ConUS beam 22500 QPSK TURBO CODED 5/6 added
Channels in the system: 6850
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.03.02
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
Pittsburgh on 77? While EA is the logical choice, they're ALREADY on 129 and 118 for some reason.
Come on, Dish, you need to put Scranton on 77!
so not gonna have epix or outdoor hd or even 12 hd channels we were told about on last charlie chat. i'm shocked.
Quite a few people will be happy to see their markets in HD going up. It will mean some changes since it is on 77w, but it is better than nothing! Surprised to see Lake Charles on 77, it would have fit nicely on the same TP as the Lafayette, LA market since that beam also covers that DMA.
Looking at some of the holes it is quite obvious seeing which HD markets will be going on E-14 at 119. Hint hint...Shreveport.
I have no idea why KPLC NBC 7 is on 77. Is it possible that it will be moved over to the 119/110/129 ?
I will try to find out more information from my contact. Obviously my contact is reliable at this point. But he did not reveal that the channel would be on the 77 satellite. I'm confused, but I admit I am not an expert on this subject. Just a viewer in the area waiting for my channels.
I wonder what they will do with 77... it doesnt make sense to load it with conus locals... i wonder if they will put E7 there when 119 is replaced? Also, why are they not mirroring the 61.5 HD to 72.7 yet? :) I thought this would occur "soon."
Come on Shreveport or Tyler, TX Locals!!! HD Please!!!!
Quad Cities HD
Does anyone know how long it typically is before the new local HD channels are available? Is it around 2-3 weeks?
Probably not.. if they go available on 77 they will probably stay there as installers would be installing 1000.4 dishes then have to swap them out. Your contact might not know. I remember hearing in another forum that KPLC stated that would be up on satellite 1Q 2010... still can't believe it. It's unfortunate they can't pull in ABC or CBS from Beaumont or Lafayette yet for the satellite locals, you'll still need OTA for that.
What's confusing is I figured that would go to 129. Waiting for that day to bring in out of markets again. Lafayette would pick up the NBC from Lake Charles, and Lake Charles would pick up ABC and CBS from Lafayette. But the way it is now they could pick up CBS and ABC from Beaumont on 61.5, although I'm not sure that beam reaches the LCH DMA. Lafayette would just snag NBC from Baton Rouge on 129.
Interesting to see how all this plays out...but I'm not holding my breath on the bill that will allow them to do this.
You'll see more migration of nationals from 77 to 72 this month.
Lots of speculation here... I'm betting the mirror of 61.5 HD to 72 will start this summer after the E14 launch. They are busy prepping for additional 119 markets. E7 could stay as a hot spare on WA or either go to 148 to hold the license.
It makes perfect sense to load 77 with HD locals..as it is speculated the mexican satellite going up there will have spotbeams due to the mixed Conus configuration needed for Mexico, they could reuse those TPs as spotbeams in the US if they are far enough from the Mexican border.
Keep an eye out in May. E14 should be coming online then. I bet they'll be active by June or July.
Sometimes a week....sometimes 2 weeks...sometimes never.
It absolutely makes sense to load it with CONUS locals because eventually the QuetzSat-1 satellite, a large spotbeam satellite will be going there in 2011. In addition, Dish should be moving more and more EA CONUS programming from 77 W to 72.7 W as more TPs on Nimiq 5 are released to Dish. E-7 should be staying at 119 W for the foreseeable future.
No one should ever accuse Dish of not stating the obvious..... :D
D
4/5/2010 12:26pm - Uplink Activity Report - 4 changes
D
4/7/2010 3:07am - Uplink Activity Report - 2 changes
