3 LNB vs 5 LNB
Rey
@ your service
27,003
586
Florida
on saturday D* installed a 3 lnb on my dish. i had a 5 lnb on my previous home. is the smaller lnb more susceptible to rain fade? its still installed on the large slimline dish. with the 5lnb I rarely experienced rain fade and on the first day of having the 3 lnb i already experienced rain fade for almost 20 minutes. the signals are in the 90's on all 4 sats. 99,101 and 103 ca cb
It could be a problem with the LNB. Or water infiltration in the LNB or cable connections.
FYI, the 99, 101, 103 LNB is housed in the same assembly regardless of 3LNB or 5LNB.
Do you get HD local stations? Some markets use the 3 lnb dish, while others are getting the locals off of the 119 so they need the 5 lnb. Maybe you moved into a different market or recently started getting the HD locals....at any rate the signal strength should be the same as long as the tech dithered the dish properly.
my locals are now off the 110 and 119 so i no longer needed the 5lnb.
here's a pic of the 3lnb swm
and a pic of the 5lnb swm
i see no water coming in the 3lnb that i now have.
Your locals were probably never on 119 to begin with (there were not ANY locals on 110 anyway...) - but when you got your first slimline, there was ONLY 5LNB models, as not all the national HD had been migrated from 110/119. Now that it is, that's way you now got a 3LNB.
That's true. There wasn't a 3lnb swm yet.
Unless you need Spanish channels or your SD locals are on 119 you dont need the 5 LNB setup
110 is vacant right now
It is nice to have the Spanish channels for a month. MY locals are SD, to I tuned to Univision HD to watch the world cup finals and had a 2nd receiver in the same room playing the english audio. :)
Iceberg is correct about most people having no need for 110/119 unless your wanting to watch the 7th day adv. or Jewish religious channels that are part of the base package but stuck on 119. I think there are still a couple SonicTap stations out there as well....but I haven't looked into it.
Which channels you like to see added on DirecTV one day?
Tipping the installer
