322 Installed Today: Questions about ReplayTv control problems.
koojoe
15
322 Installed Today: ReplayTv- TV2 Conflict -Fixed- Read If Need 'Possible' Solution
Hey guys,
Just got the 322 reciever installed and I'm having some control problems with the replaytv. It switches channels fine when tv2 is off but when tv2 is on it does not control the channels correct at all. It always goes to the wrong channel. ONLY when tv2 is on.
tv2 is UHF so this doesn't make much sense to me.
thanks for any help
Thanks for the help.
Here are my previous settings:
Enable Fine Tuning: Yes
Codeset: 0775
Send Enter: No
Minimum digits to send: 1
Inter-action delay: 0300ms
Response delay: 0300ms
Pre-command delay: 0200ms
Inter-command delay: 0300ms
My new settings that do work when both reciever outs are on:
Codeset: 0775
Send Enter: No
Minimum digits to send: 3
Inter-action delay: 0400ms
Response delay: 0200ms
Pre-command delay: 0400ms
Inter-command delay: 0401ms
I don't know exactly what fixed the problem but I know that these settings do work. I'm using a replaytv 5040 unit with a dish network 322 reciever.
Layout:
322 TV1 Out - ReplayTv - Switch - TV Input/Stereo Audio
322 TV2 Out - Switch - TV1
- Coax Split - VCR/TV2/TV3
Switch also has DVD player and VCR hooked into it. Everything on the switch is composite - red/white/yellow rca cables.
This way I can watch 322 TV2 output in either bedroom or the living room if I use the composite switch. I also can watch 322 TV1 output in the living room and control the 322 TV1 Reciever with my IR blaster on the 5040. 322 TV1 output also goes to the switch that goes to tv1 in the living room.
I hooked up everything in the living room and the dish installer just ran the cables and hooked the satellites. He told me it was too complex of a wiring diagram and if I wanted it done I would have to do it because he would be lost.
