4/26/2017 07:10 - Uplink Report - 65 Changes
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 4/26/2017 07:10 - 65 Changes
Uplink Comparison Range: 4/26/2017 06:59 - 4/26/2017 07:10 (PST)
Channel Additions:
397 - FHTBX [MPEG4 SD] added to Nimiq5 72.7W TP 07 ConUS (FHTBX)(NA)(H)
397 - FHTBX [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS (FHTBX)(NA)(H)
693 - HUMMA [MPEG2 SD] added to Anik F3 118.7W TP 26 ConUS (HUMMA)(NA)(H)
Channel Removals:
817 - ORDER [MPEG2 SD] (A) (FP) removed from EchoStar14 119W TP 10 ConUS (PPV Event Pre-Order)
817 - ORDER [MPEG4 SD] (A) (FP) removed from Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)
818 - ORDER [MPEG4 HD] (A) (FP) removed from Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)
818 - ORDER [MPEG4 HD] (A) (FP) removed from EchoStar11 110W TP 10 ConUS (PPV Event Pre-Order)
MAP Changed:
4971(8) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4971(8) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4972(12) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4972(12) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4973(14) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4973(14) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4974(6) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4974(6) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4975(6) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4975(6) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4976(6) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4976(6) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4977(9) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4977(9) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4978(41) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (41) removed (Dish Network Information Channel)(NA)(H)
4978(41) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (41) removed (Dish Network Information Channel)(NA)(H)
4979(13) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4979(13) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4980(5) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4980(5) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4981(9) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4981(9) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4982(17) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (17) removed (Dish Network Information Channel)(NA)(H)
4982(17) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (17) removed (Dish Network Information Channel)(NA)(H)
4983(10) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
4983(10) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
4984(33) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (33) removed (Dish Network Information Channel)(NA)(H)
4984(33) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (33) removed (Dish Network Information Channel)(NA)(H)
4985(13) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4985(13) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4986(9) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4986(9) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4987(7) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4987(7) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4988(6) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4988(6) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4989(8) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4989(8) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4990(3) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4990(3) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4991(5) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4991(5) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4992(7) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4992(7) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4993(4) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4993(4) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4994(23) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (23) removed (Dish Network Information Channel)(NA)(H)
4994(23) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (23) removed (Dish Network Information Channel)(NA)(H)
4995(26) - INFO [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (26) removed (Dish Network Information Channel)(NA)(H)
4995(26) - INFO [MPEG4 SD] Nimiq5 72.7W TP 15 ConUS renamed to DISH , changed to Not Available , map (26) removed (Dish Network Information Channel)(NA)(H)
5838(33) - INFO [MPEG4 SD] Echostar16 61.5W TP 14 Conus renamed to DISH , changed to Not Available , map (33) removed (Dish Network Information Channel)(NA)(H)
Tier Changed:
146 - ESPNA [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , changed to (ESPN Alternate)(NA)(H)
146 - ESPNA [MPEG2 SD] EchoStar11 110W TP 24 ConUS changed to Not Available , changed to (ESPN Alternate)(NA)(H)
147 - ESPNA [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to Not Available , changed to (ESPN Alternate)(NA)(H)
147 - ESPNA [MPEG2 SD] EchoStar11 110W TP 24 ConUS changed to Not Available , changed to (ESPN Alternate)(NA)(H)
5256(7) - WSAW [MPEG4 HD] Ciel-2 129W TP 10 Spotbeam 15 changed to Available (Mkt: Duluth,MN (WI-CBS))(A)(H)
7587(7) - WSAW [MPEG2 SD] Ciel-2 129W TP 12 Spotbeam 15 changed to Available (Mkt: Duluth,MN (WI-CBS))(A)(H)
Channel Moves:
9696 - SPORT [MPEG4 SD] Echostar16 61.5W TP 11 Conus moved to Nimiq5 72.7W TP 29 ConUS (Pay Per View Sports & Events)(A)(H)
Transponder Changes:
Ciel-2 129W TP 19 ConUS (21.500 8PSK 2/3) added.
Anik F3 118.7W TP 26 ConUS (20.000 QPSK 3/4) added.
Echostar16 61.5W TP 11 Conus (21.500 8PSK 2/3) removed.
Channels in the system: 9664
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
4/26/2017 06:14 - Uplink Report - 54 Changes
4/26/2017 07:08 - Uplink Report - 4 Changes
