OK - here's the story
I have a dish 500 system with dishpro lnbs (110, 119) with a 61.5 dp lnb hooked up also.
I also have an old FTA 30" dish - it has a ku lnb standard rf:11.70/12.20ghz, if:950/1450mhz, lo:10.750ghz, gain 55db, noise figure 0.5db
What I would like to do is use this 30" dish to hook up to 105 degree dish sat
I have a dp 34 switch, I also have available but not in use a sw21 switch.
How can I hookup all 4 sats (61.5, 105. 110, 119) to my receivers (dp501, dp301) and make it work?
Do I need another switch?
Do I need a another type lnb?
I do understand that for the 105 sat that Dish uses a different lnb - will the ku lnb I have work?
A little help would be appreciated
Thank you in advance for your time
techdss29
techdss29
