522 newbie questions
dhillii
24
Guys:
I am a current DHP subscriber (3 yrs) and have a few questions regarding the 522.
Can I use one single 522 for a PIP television? Read: can I watch 2 programs via the PIP?
Can I watch one program and record another on the DVR?
IS the DVR 100 hrs?
Is there any way to get the 522 if you're on the DHP? Even if I threat to go to Directv?
Yes, it is possible to use a TV's PIP on a 522. But then again, when set to 'single mode', you can actually use the 522's PIP on a TV that doesn't even have PIP.
Yes, in fact you can record 2 different programs while watching 2 other pre-recorded programs - though this will be taxing the sytem quite a bit.
Yes, approximately 100 hrs - give or take depending on the amount of compression in the broadcast.
I'll have to let someone else answer your last question.
Wishbone said:
Why is that? TV2 does have composite output too..
My mistake. You're right, TV2 has both RF and composite outputs, so either should work :D .
Don't know why I thought TV2 lacked video/audio out. :confused:
As mentioned, you can use the 522's native PIP to do that in single mode. Just swap the 522 in one-for-one with one of your existing receivers.
I was in the exact same situation and was able to get one. Here is a link to a post where I described what I did.
921 and Overscan - Revisited
Letters appearing on screen
