Got a couple extra remotes, but they have something in the auxiliary code. How can I get this back to nothing there ?
I've never had any luck getting any side keys back to nothing. I just change them to the same settings as the TV mode. Most of my remotes are setup that way.Got a couple extra remotes, but they have something in the auxiliary code. How can I get this back to nothing there ?
Pleas eexplain exactly what you mean. Something in the auxiliary code?Got a couple extra remotes, but they have something in the auxiliary code. How can I get this back to nothing there ?
I guess I still don't understand. If you no longer have a device in your setup why is it important to make that device code go away. Unless, of course, you want to change it to something else. Then it is simple to run the wizard and change it to whatever your new device is.I have had numerous extra devices thru the years set up in my 40.0 and 54.0 series remotes. If I no longer use that equipment and remove it you can't change the remote AUX or DVD mode setup to show nothing in the remote control menu. It stays with the last device set up in the remote. So what I do is setup the Aux or DVD mode remote control settings to the same setup as the TV mode.
I don't know.I guess I still don't understand. If you no longer have a device in your setup why is it important to make that device code go away. Unless, of course, you want to change it to something else. Then it is simple to run the wizard and change it to whatever your new device is.
It just drives me crazy!!Does this work for all remotes?You can try factory resetting the remote. Hold Sat down until all the mode lights light up, then hold home and guide down at the same time until the remote beeps out descending tones.
That's not a reset, it just delinks the remote from the hopper. However depending on the receiver software, when relinking back to the hopper as long as no other remotes are paired it does sometimes clear the codes, but not always.You can try factory resetting the remote. Hold Sat down until all the mode lights light up, then hold home and guide down at the same time until the remote beeps out descending tones.
thank you, will give this a tryYou can try factory resetting the remote. Hold Sat down until all the mode lights light up, then hold home and guide down at the same time until the remote beeps out descending tones.
You will have to re-pair the remote to your Hopper afterward. Go to your Diagnostic page, you can do that from a button on the front of the Hopper, and press Satellite on the remote. The Hopper will load the software to the remote. Whatever you have in your remote settings on the Hopper will transfer to the remote.thank you, will give this a try
