Considering running the modulated signal from a 622 into my house's antenna coax system which is run throughout the house. I have a combination adjustable amp/ splitter which takes the antenna feed amplifies it, and distributes it to up to four outputs.
Should I install a combiner (reverse splitter) with the modulated signal from the 622 before, or after the antenna amp? Obviously I would like to combine it before the amp/splitter.
Also, will the modulated signal from the 622 affect the antenna signal in any way? I have some finicky digital OTA channels.......
