622 ota antenna install help
  • WELCOME TO THE NEW SERVER!
pajer
175
North Central Pennsylvania
i just recently purcased the terk 44 clip on antenna to put on a dish, i currently have a dish 1000 pointing at 119,110,and 129 , also have a dish 300 pointing at 61.5. all have dish pro dual lnb's. it looks like i should run coax from the dish 300 lnb into the terk 44 input, come out with coax from the terk output into the dpp 44 switch and then run a coax from the dpp 44 to the input of the dpp separator and then put a diplexer between output 1 on the separator and then come out of diplexer into sat in and antenna in on the 622. is this correct?
Nope.
You've gotta diplex the OTA signal in AFTER (closer to the receiver) the switch.
The diplexers must be "facing" each other on the cable. That is, NO other device between them. Exception: the power inserter - but ONLY if the diplexer near the switch is rated for high current.
