I read on here the other day that 720p was better then 1080i. Should I set the receiver to 720p or should I keep it at 1080i.
I really didn't notice a difference when I changed to 720p.
If it is any other, say 1366x768, then you will have to try each and find which is better looking.
-Ken
I read on here the other day that 720p was better then 1080i. Should I set the receiver to 720p or should I keep it at 1080i.I really didn't notice a difference when I changed to 720p.
If you have a 1080 tv, then select that or you will get overscan.
Depending on your TV Progressive is always better then interlaced. If you have a 720p set set your box to 720p if you have a 1080p I guess 1080i is ok but for sports I would rather have 720p. If you have a 1080i which I have a tv from 6 yrs ago an LG 1080i top of the line at the time I like 720p
??? First I've ever heard, or seen, of that.
Find out if the native resolution of your TV set is 1280x720p or 1920x1080i, the official HD. Set the TV and Set-Top Box to that resolution. If it is any other, say 1366x768, then you will have to try each and find which is better looking.
Sometimes you will have a channel whose native resolution is 1280x720p, such as most ABC and ESPN channels, and does not match your TV. Then you will have to try each resolution and see which is better looking. They use it for "fast" action and lower bandwidth.
-Ken
