S
Hi everyone! I have searched both this forum & Google for an answer and have could not find anything. So I made the mistake of trying to talk to, then email Dish tech support. Anyhow, here was the exchange:
ME:
I upgraded to a 722 recently. Before the upgrade, my TV controlled my home theater (HT) receiver through HDMI. When I added the
722 to this set up (HDMI cable through the HT receiver), the connection between the TV and the HT receiver is broken. I have proven the 722 is the culprit by simply pulling the HDMI cable out of the 722 and the connection is restored. This is really annoying because I like to control the power to the HT receiver and volume by simply using my TV. I called about this and the Tech Support person suggested I program the
AUX port on the Dish remote to control the HT receiver. While this would be a band-aid, it simply doesn't work because my HT receiver has distinct codes for power on and standby. The remote's programmer decided I would like power on to be on the power button and gave me no way to turn the HT receiver off. Anyhow, unable to resolve my problem, he put me on hold for 10 minutes and then hung up on me. I could find no way to control the HDMI settings of the 722 in the menu system. I am not sure exactly what is causing the connection between the TV and HT receiver to break as I am not sure what all is involved. I just
know one of the advantages of HDMI is the communication between devices using HDMI.
Here are my system's specs (if that helps):
TV: Sony KDL-40W3000
HT Receiver: Onkyo Tx-SR705
PS3, XBOX 360, and Dish ViP 722 connected to the HT receiver by HDMI 1.3a
compliant cables.
A fourth HDMI cable runs from the HT receiver to the TV. Please pass this to your awesome tech people and see if they can figure out how to fix this issue (switching to component cables or reprogramming the Dish remote are not fixes). I have the 722 plugged into Broadband and would be happy to assist in any diagnostic efforts needed. I am a long time dish customer (7 years) and enjoy your services. Please help me!
THEM:
Thank you for your email. I’m sorry that you are having this problem. If there is an HDMI cable from the TV directly to the stereo receiver it should still work.
Our customer service center is not trained on the products manufactured by Sony or Onkyo. Their technical support will be best suited to assist you in hooking up your new product. You may also check the owner’s manual that came with the product. Usually, manufacturers include diagrams to assist you in hooking up the equipment. We apologize for any inconvenience this has caused.
ME:
Thank you for confirming the problem is with the 722. Can I get an RMA #? The Onkyo and Sony work perfectly together. You state that the 722 "if there is an HDMI cable from the TV directly to the stereo receiver it should still work." Since it does not, I must have a defective 722. Please advise on how to proceed. Thanks!
THEM:
Thank you for your email. I’m sorry but I did not say or mean to imply that there was a problem with the 722. Does the 722 work if connected directly to the TV? If it does it is not defective. As I stated we are not trained on the other products so I am not aware of why it is no longer working. You would need to consult with the manufacturer of the other devices to see what the issue is.
ME:
You're telling me that as long as HDMI transmits a TV signal that the 722 is working properly? I find that hard to believe. Since I have proven the 722 is causing the HDMI connection between the HT receiver and the TV to break, why should I contact the other manufacturers?!? They would simply tell me to contact you based on the information I have presented. Please escalate this to the engineers or RMA my 722 if it is not working as designed. Thank you very much!
Any chance of getting this resolved? I also have a 612. I am thinking about swapping it with the 722 to see if it also breaks the link. Nice "undocumented feature" if you ask me...
ME:
compliant cables.
THEM:
ME:
THEM:
ME:
