722K, LNB, or Separator
cditty
1,293
35
Northeast Louisiana
Here is the problem.
Change to a channel, receiver goes crazy counting through transponders.
Run check switch, no sat on input 2, all three ready on input one.
Disconnect separator, replace it, run check switch, runs 0-38 on each input.
Power down (removed AC), reboot, check switch, all sats fine.
This happened once before when I had a bedroom 722K (I only have the one now), so I don't think it is the receiver. Question is, do you think my LNB is failing?
Everything is working as of now.
If this just happens every now and then, then it is not really an issue. just a glitch. Every now and then Dish receivers just need to get a hard reboot to clear the system. Kinda like Microsoft.
Charlie Chat Recap 12.14.09
System Integrity Check
