shouldn't be a timer conflict, I get a conflicts if I try to record any combination of more than 2 programs on any of the tuners.
the other night I had 2 shows set to record off OTA and tried to set a program to record off sat and got a conflict??? both the sat tuners should have been free to watch or record.
SG,
    Did you read my post? Have you looked at the default Settings for your timers?
    If you have NOT changed your receivers default settings for all Timer events you will have multiple timer conflicts, as the Default settings to start early and end late will cause back to back timers to conflict resulting in the timer conflict screen and or a second event in a back to back recording event to fail to record, or no tuners free to record events.
    Example You are recording an event on one of your Local OTA channels from 7pm to 8pm and wish to record two events at 8pm on two local OTA channels. One event at 8pm will not record as the Timer from from 7pm to 8pm will run past its 8pm schedule end due to the default setting to end 2 minutes late, and remember the default setting tries to start your 8pm timers early so the Higher priority timer at 8pm will fire at 7:58 or so effectively tying up both OTA Tuners so your second 8pm timer will not be able to fire at 7:58, boom no recording for your second timer event.
    This will also happen on your satellite delivered channels, especially if you record sporting events, the default setting is for a sport timer to end 60 minutes late.
    When ever you have back to back timers DISH's default settings will tie up 2 Tuners, so will NOT be able to record more than one event back to back without changing Dish's default settings.
     I'm assuming you purchased the additional OTA tuner Module, do you have an OTA Antenna connected to your 722k's OTA Tuner Module. Be sure to record your local OTA sources from the guide using the "YELLOW" banded EPG listings not OTA channels delivered via satellite in your EPG. Let's say your local channels are 8,10,13,21,and 31. To change to a true local OTA sourced channel you would have to input 008-01 for channel 8, 010-01 for Channel 10, 013-01 for Channel 13, ...etc. If you are only keying in 8 then you will selecting a local OTA channel delivered via satellite effectively tying up one satellite tuner.
John
